Impellor Member 835 Member For: 13y 9m 8d Gender: Not Telling Posted 15/11/12 11:39 PM Share Posted 15/11/12 11:39 PM Well you could also refer to them as visual inspection units, heat exchangers, or expansion units. I must say also, that I drilled the fuel filter inlets and outlets slightly bigger (approximate size of PCV valve inlet. Jet it is important to understand that these are in operation, when not boosting. The criteria was that the plastic was impervious to oil and fuel. The best solution would be the pipercross inline filter. But if it ain't broke don't fix it. And at $3 a piece you could change them every week if you wanted.Cheers Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 7d Gender: Male Location: Sydney Posted 17/11/12 02:03 AM Share Posted 17/11/12 02:03 AM not sure if it has already been said but if your venting the catch can couldnt ya just pick one port or the other on the rocker cover and block the other one off? Save ya runnin 2 hoses..? Link to comment Share on other sites More sharing options...
Impellor Member 835 Member For: 13y 9m 8d Gender: Not Telling Posted 17/11/12 02:17 AM Share Posted 17/11/12 02:17 AM If you are venting catchcan you would run both PCV and rocker outlets to can (effectively two inlets, with vent filter as outlet). But you would have to remove the PCV valve, as the valve is inoperable without vacuum. You would also have to make sure to block inlet manifold vacuum line.This type of system would give you greatest benefits, but not legal. That said you may a potential problem with boost pressure possibly running back into the PCV, but I think doubtful, as I believe that the pressure would take the shortest route out (that is, through vent filter)Cheers Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 7d Gender: Male Location: Sydney Posted 17/11/12 02:29 AM Share Posted 17/11/12 02:29 AM I get that ya have to block off the unused bits but why would ya need to run both to the catch can when effectively in standard form only 1 can work at a time anyway. Link to comment Share on other sites More sharing options...
Impellor Member 835 Member For: 13y 9m 8d Gender: Not Telling Posted 05/12/12 03:29 AM Share Posted 05/12/12 03:29 AM Just a quick update, the plastic fuel filter idea is a failure. Can't handle the heat. Gets hot and sucks in.Cheers Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 5d Gender: Male Location: Perth Posted 05/12/12 03:36 AM Share Posted 05/12/12 03:36 AM I know how much you like alunium bits you can polish......http://www.ebay.com.au/itm/390505017063?hlp=false 1 Link to comment Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 13y 4m 24d Gender: Male Location: Sydney Posted 13/01/13 04:07 AM Share Posted 13/01/13 04:07 AM Just to clarify if you wanna make a illegal catch can you run the rocker cover breather and the PVC line to a catch can with a filter on the top and a drain in the bottom of the can? Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 7d Gender: Male Location: Sydney Posted 13/01/13 04:39 AM Share Posted 13/01/13 04:39 AM yeh that's the one.. but ya shouldnt really need to drain it often at all though the plug may still be handy. Link to comment Share on other sites More sharing options...
stee3 Member 194 Member For: 12y 10m 3d Posted 13/01/13 06:38 AM Share Posted 13/01/13 06:38 AM Picked this one up the other day bit of a custom made can. I have 2 -10AN fittings on the can and 2 -10AN fittings on the new rocker cover which is being painted at the moment. PVC valve is still in its original place and plumbed into the bottom of the plenum. Will throw more picks up when the rocker cover arrives and I fit it. 2 Link to comment Share on other sites More sharing options...
96ET Member 62 Member For: 11y 6m 11d Gender: Male Posted 21/01/13 11:26 PM Share Posted 21/01/13 11:26 PM Hey Guys,Is there anyone out there that are making bolt on catch can's for FG model falcons ?Also can anyone recommend any manufactours of quality catch can's ?Cheers, Link to comment Share on other sites More sharing options...
