August 20, 201214 yr #1 just wanted to show everyone that's curious my experiences with snow foam so far after I starting using it about a month agoFirst of all what I have usedSnow foam lanceKarcher 2.180 pressure cleanerhttp://www.karcher.c...ss/16011840.htmSnow Foam concentratehttp://www.carcarepr...w_foam_/5_litreTruck washhttp://www.chemtech....cr_ec_ct20.htmlmeguiars gold class car washThis is a video showing how it works and explains it a bit better than I can Ive found experimenting with different things what has worked for me which was to buy the pressure cleaner linked above and a snow foam lance off ebayive used those 3 liquids in it and have found the snow foam concentrate to be the best as it comes out as a thicker foam and sticks to the car bettertruck wash does well too but not quite as well as the snow foam probably 75% as good and slightly better than normal car washthe car wash worked but did not stay on the car as long as the othersI have only had a months experience with this stuff so I am not an expert but I believe my method is giving me a great resultand I will add to this post hopefully on the weekend when my car gets snowfoamed to show how much I use and what mix works wellany questions, comments, constructive criticism, ideas feel free to ask I would be happy to see this great idea take off and if I can I would like to improve my car care techniquespost away!!!
August 20, 201214 yr #2 constructive criticismI think its a load of bullocks.Offers No difference to the local car wash other than being able to do it in your drive and having to wait for the foam....then having to use a fckin cloth anyway.
August 20, 201214 yr #3 I spent 30 bucks on a normal hose spray pot (found at bunnings in the lawn care area) I use cheap repco branded carwash in the pot. I then clean with my normal mitt and gold class wash.I find swirls in the ego paint are reduced immensely as the additional suds act as a good lubricant perhaps? I also find road grime comes off far easier.Sent from my GT-P7510 using Tapatalk 2
August 20, 201214 yr #4 Author So to sum up what you have said dagabondProsHome convenience ConsTime consumingThat's good to hear old mate that's the main reason I started using it to reduce swirls in the paint and to make washing easierNot quicker but easier Edited August 20, 201214 yr by Philthy18
August 25, 201214 yr #6 Author You only use about an inch in the foam lance bottle the water down the rest of the bottleSo about the same as a normal bucket wash
August 25, 201214 yr #7 If you are washing your car with a swirling hand action your doing it all wrong from the start.If you really want to make your car easy to clean then do some research on permenon and use that.Makes dirt pretty much fall off car and paint will feel like glass!!Application is spay on wipe off.If your interested in detailing or more info checkout.http://www.fordmods.com/ford-bodykits-f15/car-detailing-tips-t14875.htmlhttp://www.fordmods.com/ford-bodykits-f15/car-detailing-tips-tricks-part-ii-t68250.htmlSome good info here.Sent from my iPad using Tapatalk HD
August 25, 201214 yr #8 Author That's why I like this snow foamThere is no swirling and the only time you touch the paint is to dry it, only problem is that you still have to scrub it if it is very very dirty but I wash once a week so it never gets that badAnd I tried this trick I Saw on you tube and it reduced the amount of water I had to chamois off by heaps Edited August 26, 201214 yr by Dagabond
August 26, 201214 yr #9 Snow foam is really only a pre wash stage to remove abrasives and dirt etc you still normally need to hand wash the car with 2 bucket method, I personally pre wash the car thoroughly with snow foam pressure washer etc then 2 buckets with grit guard and a decent microfibre hand mitt you will still get micro swirls etc with anything you do even washing the car with snow foam then pressure washers pushes the dirt across the surface. Edited August 26, 201214 yr by spinr33
August 26, 201214 yr #10 That's why I like this snow foamThere is no swirling and the only time you touch the paint is to dry it, only problem is that you still have to scrub it if it is very very dirty but I wash once a week so it never gets that badAnd I tried this trick I Saw on you tube and it reduced the amount of water I had to chamois off by heaps What do you mean by scrub?As I said, if you use permenon it makes the surface hydrophobic and hard for dirt to stick to paint work. This means a lot less friction to be used on paint surface.It puts a shine to paint work can be used on all surfaces and is UV protectant.Very easy apply after you cleaned cars surface you put 10ml permenon in 200ml of distiled water and mist on to surface with spay bottle.You then wipe on panels with microfiber cloth and use another to dry off.You re-apply if you run finger along paint and it grips or makes that squeaking noise.The paint just feels so slick and re application approx 3months.I can't believe how easy the car is to clean most time quick highpressure hose and then a wipe of all panels in one direction with microfiber cloth and some times with a little quick detail spay.It cost approx $45 for 100ml. Sent from my iPad using Tapatalk HD
