  • Thooperrrrrrr
  • Legacy Donating Member
  • Member For: 15y 3m 3d
Posted
Yup usually have about a 3rd of a bottle left after a flush here.
  • Member For: 15y 5m 29d
Posted
If you own a compressor get a vacuum bleeder and its an easy 1 person job, you dont even have to press the pedal.
Yeah we use a suction pump at work in same fashion for fluid change. Although a proper two person bleed always yields better results if done properly. The vacuum can sometimes draw air through the thread.
If the nipples aren't drawing don't stress. Fully undo them unblock the little hole with a pin or needle then smash compressed air down it. Put it back in and all good :)
Guest XR09
  • Guests
Posted
Try bleeding bloody Honda's linked brake system without a speedbleeder. Hide the oxy first or you will burn the bike.
  • 4 weeks later...
  • Member For: 14y 8m 26d
Posted
hey guys, can anyone tell me what sort of milage, the brake fluid should be changed at? I'm at 53,000 and im about to change pads over as there shot.
cheers
  • Moar Powar Babeh
  • Member For: 21y 12d
Posted
change pads/change fluid. Fluid is cheap, brake system failure is not :spoton:
Posted
The car is a late model 2010 mate. what do you reckon?
  • Member For: 20y 4m 8d
Posted
should be close to being due for a change, should be changed every 2 years and always use fluid from a sealed container
