Robos F6 Donating Members 407 Member For: 16y 2m 7d Gender: Male Location: Vic Posted 18/05/12 08:22 AM Share Posted 18/05/12 08:22 AM Just put a dump pipe on and now my car is only running 11psi. Tuner maxed out the boost and this is much as it could be dialed in.So ive got a actuator ready to go on.Any instructions on how to do it or any nasties I shall encounter? Link to comment https://www.fordxr6turbo.com/forum/topic/80209-how-to-change-actuator/ Share on other sites More sharing options...
riptide Member 733 Member For: 14y 3m 21d Gender: Male Location: Auckland, New Zealand Posted 18/05/12 10:57 AM Share Posted 18/05/12 10:57 AM Have a look here.You would be best to port the waste-gate too. I used a spherical carbide burr and leather gloves (for max control) and remember the "D" shape so the back of the flap doesn't catch.I think you should put regulated air on the actuator to test that it can open fully on the bench. This is a must and something that may have cost me an engine.Also Nord-Lock washers should be used under the nuts to stop the turbo working loose (cheers hawlass ) Link to comment https://www.fordxr6turbo.com/forum/topic/80209-how-to-change-actuator/#findComment-1239426 Share on other sites More sharing options...
Robos F6 Donating Members 407 Member For: 16y 2m 7d Gender: Male Location: Vic Posted 19/05/12 11:48 AM Author Share Posted 19/05/12 11:48 AM How do you get the sirclip off with the turbo on the car? Link to comment https://www.fordxr6turbo.com/forum/topic/80209-how-to-change-actuator/#findComment-1239920 Share on other sites More sharing options...
Robos F6 Donating Members 407 Member For: 16y 2m 7d Gender: Male Location: Vic Posted 19/05/12 01:15 PM Author Share Posted 19/05/12 01:15 PM Ok done it, easiest way is to take the dump off. Link to comment https://www.fordxr6turbo.com/forum/topic/80209-how-to-change-actuator/#findComment-1239966 Share on other sites More sharing options...
Haydo83 Member 17 Member For: 12y 10m 28d Gender: Male Location: Newcastle NSW Posted 22/08/12 12:09 PM Share Posted 22/08/12 12:09 PM Absolute sh*t of a job to do if u dont take dump pipe off,I havnt tested my actuator on a bench but I prob should take it out and do so cos I currently have no boost anyway cos I cant get c clip back on but next attempt is taking the dump pipe off Link to comment https://www.fordxr6turbo.com/forum/topic/80209-how-to-change-actuator/#findComment-1283436 Share on other sites More sharing options...
Haydo83 Member 17 Member For: 12y 10m 28d Gender: Male Location: Newcastle NSW Posted 22/08/12 12:13 PM Share Posted 22/08/12 12:13 PM oh and a silly question.could u do any damage to a new actuator by manually pulling the arm,not very much and turning the arm just to line it up with the flapper arm it just made a bit of a dry rubbing noise Link to comment https://www.fordxr6turbo.com/forum/topic/80209-how-to-change-actuator/#findComment-1283439 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 8d Gender: Male Location: Adelaide Posted 22/08/12 01:02 PM Share Posted 22/08/12 01:02 PM nup u can flog the chit out of it all day long , if its a quality unit it can take pulling and twisting no worries Link to comment https://www.fordxr6turbo.com/forum/topic/80209-how-to-change-actuator/#findComment-1283470 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 3m 21d Gender: Male Location: Auckland, New Zealand Posted 23/08/12 08:00 AM Share Posted 23/08/12 08:00 AM Always had to twist mine to get them to line up. No ill effects so far... Link to comment https://www.fordxr6turbo.com/forum/topic/80209-how-to-change-actuator/#findComment-1283853 Share on other sites More sharing options...
Haydo83 Member 17 Member For: 12y 10m 28d Gender: Male Location: Newcastle NSW Posted 24/08/12 12:34 PM Share Posted 24/08/12 12:34 PM Ok thanx heaps yeah I was a bit worried when I spun it I thought id ruin it.that's good to know Link to comment https://www.fordxr6turbo.com/forum/topic/80209-how-to-change-actuator/#findComment-1284633 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 11d Gender: Male Posted 24/08/12 12:48 PM Share Posted 24/08/12 12:48 PM You should also put half a hole preload on the actuator arm 1 Link to comment https://www.fordxr6turbo.com/forum/topic/80209-how-to-change-actuator/#findComment-1284640 Share on other sites More sharing options...
