  • Legacy Donating Member
  • Member For: 15y 1m 14d
Posted
Just wondering can a switch be ran so I could switch on my thermo fans when ever I needed to?
Or will doing anything like this affect the computer?
  • Member For: 20y 3m 29d
Posted
Why would you? the ecu controls them quite well and temperature to cut in can be adjusted in the tune.
I have seen way too many cars that have their fans hard wired to a switch, only for the owner to forget about them until things start to boil, most owners are diligent about watching the temp gauge but as time goes by they forget.
  • Member For: 17y 10m 3d
Posted
You can run a switch but if you bypass the PCM it will probably throw codes.
Your car should already know by itself when it needs cooling.
  • Member For: 15y 11m 21d
Posted
can you put a switch in and keep the ecu's auto sensor too?
Posted
Lol ratter beat me by a bees dick.
you snooze, you lose :sleep:
Posted (edited)
I'm not an auto elec however I have reason to believe that if you do this and have the fan switch in the on position, then the pcm decides to switch it on as well you will blow the fan fuse(s) in the car.
You would need some input back into the pcm to tell it that the fan is running. Also, not sure if the pcm knows the fans RPM, if so this will further complicate things.
Edited by Paulie2256
  • Sucker
  • Moderating Team
  • Member For: 22y 5m
Posted
I believe all the ECU does is earth the relay(s) trigger, so can't see how it could cause issues being earthed twice.
Only one way to find out...
:nyyaah:
Posted (edited)
Fark it back to the tuner I go :)
Apparently my fans were set to come on earlier but they don't come on untill a bees dick under half!
Edited by Kosij
