4L JET Legacy Donating Member 230 Member For: 15y 1m 10d Gender: Male Location: Adelaide, S.A Posted 15/03/12 10:58 AM Posted 15/03/12 10:58 AM Hey Guys,Been looking for some new shoes and thought about doing convo pros for something different. ive only seen one in SA with them and it hasnt been hitting the streets much.Anyways my question was how can I fit them on my BF turbo if they only come in a 15" rim size as im fairly sure a 17" minimum is needed to clear the brakes.And what is the widest rim/tyre u can put on the front and back without it scraping on the inside guard? My car is standard height for now. I dont plan on lowering it until after the rims go on.any help is greatly appreciated. Cheers
Paulie2256 Legacy Donating Member 7,441 Member For: 17y 10m 15d Gender: Male Location: SE Melbourne Posted 15/03/12 01:06 PM Posted 15/03/12 01:06 PM Ask staino
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Legacy Donating Member 9,946 Member For: 18y 6m 17d Gender: Male Location: Vic Posted 15/03/12 06:44 PM Posted 15/03/12 06:44 PM +1.
Pazzo Legacy Donating Member 11,132 Member For: 15y 11m 15d Gender: Male Posted 15/03/12 07:09 PM Posted 15/03/12 07:09 PM +2
freeze_dk I am dissatisfied with my current employment situation Legacy Donating Member 8,610 Member For: 20y 9d Gender: Male Posted 15/03/12 07:38 PM Posted 15/03/12 07:38 PM =4
STAINLESS again plz You've changed man.... Legacy Donating Member 8,142 Member For: 15y 9m 10d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 15/03/12 07:43 PM Posted 15/03/12 07:43 PM Go away
Shyfrd Turboless Legacy Donating Member 5,992 Member For: 15y 7m 9d Gender: Male Location: Geelong, Victoria Posted 15/03/12 07:49 PM Posted 15/03/12 07:49 PM Don't be a *beep*, help the fella out lol.Look up stainos profile n open topics he started. He's got one up for the tray with some info about what he did for the convos
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Legacy Donating Member 9,946 Member For: 18y 6m 17d Gender: Male Location: Vic Posted 15/03/12 07:54 PM Posted 15/03/12 07:54 PM Find the thread were staino asked how to fit them. Prepare to be mind fucjed. 1
Paulie2256 Legacy Donating Member 7,441 Member For: 17y 10m 15d Gender: Male Location: SE Melbourne Posted 15/03/12 08:10 PM Posted 15/03/12 08:10 PM (edited) You 1st things 1st.Get a plasma gun and cut out the back seats and boot. If you have a ute do it anyway.Staino will then build you his custom tray.Only then should you go and look at his thread. Easiest way. Edited 15/03/12 08:11 PM by Paulie2256
STAINLESS again plz You've changed man.... Legacy Donating Member 8,142 Member For: 15y 9m 10d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 15/03/12 08:48 PM Posted 15/03/12 08:48 PM (edited) Rears, 8.5" with 5" backspace may fit in the guards but I cant say for sure, or if they will foul on your springs. (most likely not) also depending on tyre choice.Providing you only have the factory brakes they will clear the calipers. (Brembos dont even try)If your after deep dish like mine (3 3/8" backspace) you will need to shorten your diff around 180mm or do some serious guard pumping lol. 80mm each side.Fronts, you need to downgrade calipers and rotors to BA spec or NA spec, ie 298mm rotors. 6" with 3 3/8" backspace sits spot on in the guards on my fg.I wish I was around when I was trying to do this If I had my time again I would go THIS: with 15" rears and 17" fronts.p.s. now go away Edited 15/03/12 08:54 PM by STAINOnegger 1
