  • Member For: 14y 6m 26d
Posted (edited)
Hi all new to this forum I was hoping to get some advice on how to convert my standard computer to something a bit mote advanced,I own a 07 bf xr6t mk 2 utility cheers!
Edited by Tglamo
  • Legacy Donating Member
  • Member For: 17y 9m 26d
Posted
If you are referring to the ecu by which I mean PCM what would you be doing that would require a "more advanced" one.
If you are referring to the screen in the centre then no.
  • Member For: 19y 11m 20d
Posted
Install windows 7 32bit..
Posted
Hi all yes apologies meant the ecu adding in a flash tuner and the best approach on instalation etc,I am new to the turbo scene and was more alese keen to gain a bit more power from my stock unit as is. Cheers
  • Thooperrrrrrr
  • Member For: 15y 2m 15d
Posted (edited)
Have a read through this thread
http://www.fordxr6tu...pic/32273-edit/
Most common unit to make adjustments is the Xcal3, the software though I'm not sure - SCT Flash something or other?
Edited by Ciaran
Posted
Flash tuner is a plug and play hand unit.. Dont have to mod the ecu,, it just installs tunes
Posted
Hi ok cool sorry about the little knowledge I have as I am a 8 convert lol,great tips so would I be going down the right avenue to get mild power increase from my ute as I am not happy with the stock and what it puts out,I don't want to spend a dime on aftermarket upgrades just the easiest and most cost effective way to gain a bit more power..:)
Posted
Cold air intake and tune will be around 250rwkw.. What ute? Manual auto?
  • Member For: 19y 3m 22d
Posted
If you already have a flash tuner then a custom tune is the next cheapest thing to do to make power. Just ask them to get the most power they can out of it within the safety limits of the stock gear.
