  • Member For: 14y 7m 14d
hey guys I'm very interested in the aeroforce interceptor gauges I was just wondering if anyone has the part number for the kit for the 2003 ba xr6t ute or no of a Australian distrubuter for these gauges any help would be very appreciated.
https://www.fordxr6turbo.com/forum/topic/78303-interceptor-gauges/
  • Member For: 16y 2m 18d
Ive got an aeroforce gauge, you can either email aeroforce direct and tell them what car you have or talk to Xtreme Auto Gauges in Aust (however not sure if they still exsist as website doesnt work)
From memory I just emailed aeroforce direct, just remind them you want it in metric :D
Thanks for the reply how do you rate the gauge does the shift light work well do you find it reads boost right, do you just connect to obd 2 and the gauge is good
  • Member For: 21y 10m 15d
I have dual gauges on my BA Turbo and think that they are great. Its a simple plug and play but you will need to read the manual to set what you want to display (boost for instance) and then the shift/warning lights which is what they call Annunciator. If your system isn't reading correct which mine is then you can change the main settings to correct the voltage offset (again, read the manual).
The BA's have limited info display but I use Boost, Water temp, Intake charge temp and Timing Advance. There is also two analogue inputs on each guage so I will be doing Trans temp and Fuel pressure later on.
The BF, FG's should have allot more available info like trans temp already, knock detection.
I ordered mine from xtremeautogauges and paid $530 delivered for the two gauges but he was closed the last time I went to buy some sensors! Here is the link for the other dealers http://www.aeroforcetech.com/dealers.html
Hope this helps
  • Member For: 15y 6m
I have dual gauges on my BA Turbo ..............
So is the dual gauge kit for the BA/F required the CNF type. Also with the duals you can have 4 diff parameters and the shift light on one right?
So say Boost, oil temp, oil press, and water temp plus the shift light is what im getting at.
Cheers in advance bjc or anyone else who knows.
I didn't have to worry about the FD/CNF thing as I bought mine in Australia but I'd say CNF type gauge being obd2 plugs on our cars.
Yes you can have 4 parameters with the shift light on the one gauge
yeh I decided I only wanted 1 gauge as I only want it for the shift light boost and water temp I dont think it can read oil pressure on the ba falcon I may be wrong anyways hope to receive my cnf gauge some time this week
Edited by relentless xr6
