Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 1m 17d Gender: Male Location: Melbourne Posted 26/12/11 06:52 AM Share Posted 26/12/11 06:52 AM It's modified. Link to comment https://www.fordxr6turbo.com/forum/topic/78295-help-strange-noise/page/2/#findComment-1173525 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 8m 21d Gender: Male Posted 26/12/11 06:54 AM Share Posted 26/12/11 06:54 AM Still worth a shot being gearbox related not engine? Link to comment https://www.fordxr6turbo.com/forum/topic/78295-help-strange-noise/page/2/#findComment-1173526 Share on other sites More sharing options...
RIP_HSV HOON Member 1,636 Member For: 15y 3m 28d Gender: Male Location: W.A Posted 26/12/11 07:02 AM Share Posted 26/12/11 07:02 AM wheres "Pat the Panda"? Link to comment https://www.fordxr6turbo.com/forum/topic/78295-help-strange-noise/page/2/#findComment-1173528 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 2m 17d Gender: Male Location: Victoria Posted 26/12/11 07:03 AM Share Posted 26/12/11 07:03 AM Engine and driveline warranty would be gone.Thrust bearings won't be noisy with the clutch out. It's only when you push the pedal in that they load up on the pressure plate and start spinning. Link to comment https://www.fordxr6turbo.com/forum/topic/78295-help-strange-noise/page/2/#findComment-1173529 Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 6m 16d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 26/12/11 07:30 AM Author Share Posted 26/12/11 07:30 AM Was fine thismorning when arrived at park. Went to bottleshop on web street and hit the hump in driveway pretty hard on the middle resonator. . Didnt notice anythin drivin back to park. But soon as turned key comin home was makin noise. I first thought was the bracket I made mounting dump pipe to gearbox but that looks fine. Link to comment https://www.fordxr6turbo.com/forum/topic/78295-help-strange-noise/page/2/#findComment-1173534 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 8m 21d Gender: Male Posted 26/12/11 07:39 AM Share Posted 26/12/11 07:39 AM 1 Link to comment https://www.fordxr6turbo.com/forum/topic/78295-help-strange-noise/page/2/#findComment-1173535 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 1m 17d Gender: Male Location: Melbourne Posted 26/12/11 07:43 AM Share Posted 26/12/11 07:43 AM Link to comment https://www.fordxr6turbo.com/forum/topic/78295-help-strange-noise/page/2/#findComment-1173536 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 7m 21d Gender: Male Location: SE Melbourne Posted 26/12/11 07:49 AM Share Posted 26/12/11 07:49 AM Engine and driveline warranty would be gone.Thrust bearings won't be noisy with the clutch out. It's only when you push the pedal in that they load up on the pressure plate and start spinning.Pretty sure you're talking about the spigot bearing but haven't had my tr6060 for very long. Link to comment https://www.fordxr6turbo.com/forum/topic/78295-help-strange-noise/page/2/#findComment-1173538 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 2m 17d Gender: Male Location: Victoria Posted 26/12/11 08:20 AM Share Posted 26/12/11 08:20 AM No. The spigot bearing is in the flywheel and does nothing more than locate the end of the trans input shaft. Link to comment https://www.fordxr6turbo.com/forum/topic/78295-help-strange-noise/page/2/#findComment-1173544 Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 5m 12d Posted 26/12/11 08:33 AM Share Posted 26/12/11 08:33 AM Ummm,I think you will find the spigot bearing does spin when the clutch pedal is pushed in... Why else would they have a bearing there? Some cars even have a bush bearing instead of an actuall roller bearing. Some smaller cars with shorter input shafts,dont have either type,so the input shaft doesnt locate in jacksh*t.Sounds like bad noises Ben. That aint any type of acceptable rollover noise if its your gearbox. Link to comment https://www.fordxr6turbo.com/forum/topic/78295-help-strange-noise/page/2/#findComment-1173547 Share on other sites More sharing options...
