  • Member For: 17y 2m 7d
I remember your box getting coolant through it. was that at 20,000? what happened at 25,000?
Edited by bluprinturbo
  • Member For: 21y 5m 5d
I can see where you're coming from dillz but why would you go through sooo much running around, phone calls, stress, f*ck arounds, waiting and money for something you can do easily on a stock FG F6 engine with valve springs thrown in to 'play it safe'. Just do a manual conversion in the G6E!
  • Pitlane Member
  • Member For: 18y 2m 17d
This man... What he says makes a lot of sense!
what he said ^ get the zf done by that wa mob who did qik 1 and t-freak. shouldnt need to at your power level. surely it must be a faulty box.
  • Here since the start...
  • Member For: 22y 2m 22d
Strengthening the ZF won't make any difference to the heat exchanger. That's where his problems have comes from.
  • Member For: 14y 8m 26d
Going manual is a lot more than you think, pedals,tailshaft,different diff ratio,gearstick,oil reservoir, don't know if missing anything else, Ratter would know. Do manual's have a different tune to auto's?
  • Three pedals are better then two..
  • Member For: 18y 1m 22d
:stupid:
Also turning it into a manual is an expensive exercise and devalues the car significantly.
  • Member For: 15y 10m 1d
Just ditch the heat exchanger all together and go with a transcooler..
