  • Member For: 15y 5m 27d
Posted (edited)
Just wanting opinions on possible diff problems before I go and see someone on tuesday, Maybe someone else has had this problem.
When taking a left hand corner or swerving left and right to perform an S you can hear grinding what I can't tell is where it is coming from.
If I place my hand on the centre console cover u can physically feel grinding and slight knocking when flicking the wheel left and right (this is the best way to produce the problem).
Anyone have any ideas ? Half shafts ? diff internals ?....
I had my diff bushes replaced at wholesale suspension and it feels great and has eliminated all associated bush drama's but this grinding was there before and still remains afterwards.
Also, I have jacked the car up and spun the wheels and there seems to be a slight lag before the opposite side wheel engages and spins. On most holdens I have owned the opposite wheels instantly spins on an LSD.
Any info is most appreciated ! :buttrock:
Edited by helbz
  • Legacy Donating Member
  • Member For: 19y 4m 11d
Posted
I thought that was normal, the Limited Slip part?
  • It's All In Your Mind
  • Member For: 22y 11m 8d
Posted
Maybe its in the front end? Check front hubs (wheel bearings) mine was similiar until I replaced them.
Posted (edited)
Interesting, Do you think I would feel the vibration/grinding under the centre console if it was front wheel bearings? I thought this vibration I can feel through the console lid would be from the box back ? And any wheel bearings I have had go in the past they usually have a howling sound.
The sound/grinding was there before and after a diff oil change
Edited by RHR
No need to quote above post. USE FAST OR ADD REPLY
  • 3 weeks later...
Posted (edited)
Just incase anyone wants to know in the future my problem was the mount on the gearbox was causing all these problems, The Xforce exhaust when the car was cold was clearing the chassis and when hot would grow and touch the chassis. I replaced the gearbox mount as you could visually see it was torn and once replaced moved the box into its correct position, this then moved the exhaust across and was rubbing on the chassis full time. A few mods to the exhaust and both problems are fixed. $140 from ford for mount and $40 to fit it. It's like a new car now
Edited by helbz
  • Member For: 18y 4m 26d
Posted
auto or manual.
This could be my problem. I have a vibration and have had it with 2 different diffs. It goes away for first 10kms when I swapped the diff but was back after giving it some stick. could be gearbox mount for sure.
cheers
Posted (edited)
It's a ZF Auto mate, If this is your problem you will know as soon as the mount is replaced as the exhaust will be extremely close to the chassis and need to be modified with solid rubber exhaust mounts or the pipe heated and bent into place. This problem is a direct result from people installing an aftermarket exhaust when the gearbox mount is torn.
Edited by helbz
