  • Member For: 16y 10m 29d
Posted
Hey guys
If I was to purchase a bf post 06/06 and install a rapid v2 intercooler with hot and cold side piping plus injectors, walbro fuel pump and a tune would 320 rwkw be achieveable?
  • Legacy Donating Member
  • Member For: 18y 5m 28d
Posted
Probably need to throw in a high flow cat as well. Should see
Low 300s easy then.
  • Banned
  • Member For: 17y 1m 30d
Posted
and remove the middle muffler with the hiflow cat. should be good for 320 without too much boost dramas at all
  • Member For: 16y 2m 17d
Posted
Yeh mate as others have said, basic mods will get you low 300's. Add porting and actuator to the list and see quite abit more again !
Posted
Where should I purchase the hi flow cat? And what should I expect to pay? recommendations?
What do you think id be looking at t get an exhaust shop to remove the centre muffler and install the hi flow cat.
  • loitering with intent
  • Member For: 23y 29d
Posted
Speak to Rapid ( Chris ) he will set you up with a cat. Give him a call.
Remove centre muffler to a straight through ~ $100, as for fitting the cat speak directly to Chris or your Zorst shop as they will be closer to itspoton.gif
  • Member For: 18y 8m 2d
Posted
thanks guys
so a hi flow cat shouldnt be to pricey then
I have an 04/06 BF auto and achieved 295kw with a highflow cat (rapid $199?), injectors ($350), sct box ($700), F6 intake and K&N panel filter ($200). I think the cat was about $100 to fit. I was told that an intercooler would have allowed them to achieve a few more KW. I am looking to do dump pipe and V3 kit next.
Good luck
