MY ROD GOT OUT Member 434 Member For: 16y 27d Posted 02/11/10 10:05 AM Posted 02/11/10 10:05 AM hey everyone im sure this has been covered before but im hopeless at searching , I need a set of injectors and a pump, I have a tune booked in monday and need them asap... im guessing 60lb seimens for injectors but not too sure of which pump... and if anyone knows of a good place to purchase these items on the goldcoast or brisbane??? or approx how much should I be paying for these items??? thanks everyone.ps: had a dyno run last monday with a crappy generic capa tune (10psi), it did 354.4hp but I set it to the generic 8psi tune as it was lean as!! hence the choice for proper tune....... so hopefully with injectors and pump I'll be in the 300+ club???
Worm A much better forum Legacy Donating Member 3,808 Member For: 18y 2m 8d Gender: Male Location: Victoria Posted 02/11/10 11:28 AM Posted 02/11/10 11:28 AM What's done to car mate?Walbro intank pump.. I think gss341 is a goer... Or Bosch 044... Bosch is very noisy. If you have cash, hiro performance is selling cheap process west surge tank kits...What car do you have? Modded valve springs? Dump? Stock cat?
MY ROD GOT OUT Member 434 Member For: 16y 27d Posted 02/11/10 11:34 AM Author Posted 02/11/10 11:34 AM (edited) hey mate, full exhaust ( not sure off brand etc but my mechanic said its a full system) , hdi intercooler and f6 2nd cai with k&n panel filter. so hopefully with pump and injectors and finally a proper tune I should be makin decent power. Edited 03/11/10 10:02 AM by RHR No need to quote above post. USE FAST REPLY
icer Banned 2,335 Member For: 17y 2m 14d Gender: Male Location: Aspendale, Vic. Posted 02/11/10 11:37 AM Posted 02/11/10 11:37 AM if its a BA or PRE 06 BF then your valve springs will let you down and you will see 260-270rwkw. apart froim those, you should see 310-320.
MY ROD GOT OUT Member 434 Member For: 16y 27d Posted 02/11/10 11:44 AM Author Posted 02/11/10 11:44 AM its a BF built FEB 06, so im assuming the valve springs will be ok??? wouldnt getting 354.4hp (approx 260rwk) with a generic 10psi capa tune mean with bigger injectors and pump plus a proper tune see me into the 300's????
icer Banned 2,335 Member For: 17y 2m 14d Gender: Male Location: Aspendale, Vic. Posted 02/11/10 01:23 PM Posted 02/11/10 01:23 PM unfortunatlly no, you need post 06/06 for stronger v/springs from my understanding. So you will be limited to 260-270. Some cars tip 300rwkw with stock v/springs but they are one in a million.Your generic tune of 260 might (most likley is) be running LEAN and can be damaging your motor every time you push it. Generic tunes are for the bin. There are NO good generic tunes. you might be maxing out everything to get your current 260rwkw, but with your additional mods you should see 270rwkw but not limiting anything and leave room for more power once vsprings are swapped.
MY ROD GOT OUT Member 434 Member For: 16y 27d Posted 02/11/10 09:05 PM Author Posted 02/11/10 09:05 PM ah ok, how much are vsprings??? if it fits the budget I might add them as well
Redback Banned 236 Member For: 17y 3m 20d Gender: Male Location: Blacktown NSW Posted 02/11/10 09:54 PM Posted 02/11/10 09:54 PM I have an 05 BA . When I had similar mods you're talking about I made 318rkw on CV DYNO. My valve springs at the time held. However if you don't want to waste money on the dyno, replace the valve springs before you tune. A set of Atomic springs are about $350. You can hire their tool to change them yourself, otherwise you need a mechanic to install them as they are a fiddly job.
MY ROD GOT OUT Member 434 Member For: 16y 27d Posted 03/11/10 09:20 AM Author Posted 03/11/10 09:20 AM stick ok so I've decided to stick with stock valves as I didnt budget for $400 for springs and $250 to install them. so I'll get the pump and injectors with proper tune and we'll see how we go., unless anyone has some cheap springs lying around thanks every1
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Legacy Donating Member 9,946 Member For: 18y 6m 11d Gender: Male Location: Vic Posted 03/11/10 09:33 AM Posted 03/11/10 09:33 AM *Beep* to the rescue. Your Bf valve springs are good for high 300s, you won't need to replace them till you need to replacembottom end/auto etcWith your mods ild guess you'll get 340s with injectors and fuel pump
