discostig Manual mode ________________________ All day, erryday Legacy Donating Member 13,798 Member For: 18y 10m 12d Gender: Male Location: Probably above atmospheric pressure Posted 10/10/10 02:29 PM Posted 10/10/10 02:29 PM (edited) I'm running 317rwkw through the ZF auto and I'm using 42lb injectors. Full Manta 2x2.5" exhaust with twin cats, Nizpro cooler to stock crossover and intank pump upgraded to a Walbro GSS 294. 60's are good insurance in case you want to go to higher power levels, my injectors have seen at MOST 350ish, but more commonly low 330 max.You don't wanna be running injectors at 100% duty cycle (I'm close enough now)! Also dyno figures can be fudged to be higher than they really are - it's mainly a tuning tool not a true test of power. Edited 10/10/10 02:34 PM by -SteveR-
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Legacy Donating Member 9,946 Member For: 18y 6m 16d Gender: Male Location: Vic Posted 10/10/10 06:35 PM Posted 10/10/10 06:35 PM The cat has made nearly no difference. Only change is it's a bit louder on cold start, other than that it's not a bad sound. Used to drone a touch but at certain revs but it's got rid of that. It's a bit louder when under it though.
jonn Member 141 Member For: 17y 9m 22d Gender: Male Location: Carrum, VIC Posted 11/10/10 06:41 AM Author Posted 11/10/10 06:41 AM You don't wanna be running injectors at 100% duty cycle (I'm close enough now)! Also dyno figures can be fudged to be higher than they really are - it's mainly a tuning tool not a true test of power.ahh yer makes senceill probably be upgrading cars in a couple years, maby to a fg mk2 if they exist. so looks like im gonna stick the the custom tune and leave it at that.
