  • Member For: 17y 7m 25d
Posted
Hopefully someone might be able to help me because ELN Ford at Tuggerah can't, but happy to charge me to tell me that!
Been having issues with the XR6 BFII N/A not wanting to start.
It will start probably 6 out of 10 times ok.
But, the other 4 times I need to give it a few spurts of the throttle so it doesn't die.
Sometimes even that doesnt help. After I turn the key it tries to start, then nothing. If I keep the key turned it will try to fire again prob 2 secs after it fails and chokes into action. It mostly gets going on the second attempt but it has taken 3 goes before.
Like I said, ELN Ford at Tuggerah "couldn't fault at time of testing". The service I just had performed by them hasn't helped either as it failed to start first attempt the next morning after picking it up.
According to the tax invoice they also charged me for new wiper blades and soap for the washer fluid, but there's no soap in the washer fluid and the wiper blades still scrape across the wind shield! They also charged me for oil, beginning to wonder if they even changed that!
Is anyone able to diagnose this problem? Or know what parts might be playing up?
Cheers
  • 2 months later...
  • New Member
  • Member For: 17y 9m 6d
Posted
I know this is a bit of a slow reply...
But yeah I have the exact same problem with mine. Auto elec couldnt find a fault, Ford couldnt find a fault... Auto elec suggested it could possibly be this thing that sorta determines how much fuel it puts in. Said that or fuel pump, but I dont think its the fuel pump because its faultless anywhere else... I find that the better the fuel I put in, the less it will happen, maybe 30-50% of the time with 91, 20% of the time with 95, and about 10% of the time with 98 stuff...
  • Legacy Donating Member
  • Member For: 18y 10m 11d
Posted
Pos dumb suggestion but what about plugs n coil packs? Smaller spark from these being stuffed will struggle to burn the lower octane? :icon_ford:
Posted
Or regulator, or tps...
  • My new toy
  • Member For: 23y 4m 29d
Posted
you may find the fuel pump is leaking back not holding pressure and this causes it to not start.
It will loose pressure every time it stops but if it sits for some time the fuel in the injector rail evaporates so makes the motor hard to start.
Ian
Posted
Yup, had the evaporation prob in a s4 rx7turbo years ago-bloody annoying!
  • Member For: 17y 2m 5d
Posted
take out one of your spark plugs and if its all black chances are your cat has probably shifted a little, does it stutter under hard acceleration
  • 3 weeks later...
  • New Member
Posted
Quick update I got a new battery about a week ago, and it hasnt failed to start first go since...touch wood! :icon_ford:
  • 5 months later...
  • Member For: 15y 9m 8d
Posted (edited)
mate possible might have water in the fuel tank its a little up there suggestion but my turbo strugleed to start when it had water in the tank all the best
Edited by Relentless xr6t
  • 3 months later...
Posted
Haven't checked this for awhile, but just had a service from Klosters in Newcastle. I told them about the problem and they said the throttle body probably needs cleaning. They did it for $159 and I haven't had a problem starting since! The car also feels alot smoother under acceleration. The exact description of what they did was:
"Carried out induction and combustion system service cleaning air intake system, inlet valves, EGR valve and combustion chamber from excessive carbon deposits..."
