  • Member For: 16y 4m 10d
Posted
Has anyone else had a problem with the Bluetooth? I have an 09-plated, and an iPhone with the latest software. I can make calls fine, but I cannot for the life of me recieve them!! It shows on the screen, I press the steering wheel button, and then the screen says 'Disconnected', and the call is received on my handset. All the settings I can see on my phone say handle with Bluetooth. Anyone?
Guest XR09
  • Guests
Posted (edited)
I had the same problem with my Nokia. My sevice man tried to tell me the phone was not compatible with the car. Yet it showed what phone it was on the screen. After a little rant and rave by me they reflashed ??? the bluetooth and I have not had a problem since. To be honest I have no idea what they did. Blue tooth has so few protocols there really is not much you can do but have Ford try and run the lastest update in it.
Edited by XR09
  • Sucker
  • Moderating Team
  • Member For: 22y 4m 22d
Posted
The iPhones are notorious for having issues so it that could be your problem. Have you got another phone you can try to rule that out?
I had a few issues with mine failing every now and then where the bluetooth interface just simply wouldn't work (couldn't select it in the ICC) and would have to pull the fuse to reset it. Module was replaced under warranty yesterday so hopefully that's the end of that.
Posted
Yea, I approached the ford guys and they asked me "do I know how to change the settings on the phone, because there is no problem with the car", amongst other little gripes. I guess if other ppl have had problems, might tell them to reflash it and see if that helps. I guess it can't make it worse, theoretically. I just couldn't fathom a car that is iPod/iPhone friendly, that it doesn't work properly with the damn thing.
  • BOOST
  • Moderating Team
  • Member For: 23y 11d
Posted
Got an Iphone here and no problems at all
Posted
Hey prudent,
thx very much for that. I spoke with the service guys and said that I had an answer off the xr6turbo forum, to which the reply came "I don't listen to the crap off the forums." However, they have booked it in and I would imagine that they will upgrade the software and it'll work fine! I think they just get jealous that there are ppl out there that know more than they do!!!
Thanks heaps for that. Will let you know if that was the culprit.
  • Inactive Members
  • Member For: 16y 9m 28d
Posted
Hey guys
I am having the same issues with my iphone connecting to bluetooth. The car was built 9/09 and I think I may have an older module. Apparently it has the latest software but still plays up. How can I tell which bluetooth module is in my car? where is it?
Thanks
  • Sucker
  • Moderating Team
Posted
I assume it's in the centre console where the iPod connector plugs in? :bangcomputer:
lol...it's a bit upsetting for the "nobody knows your ford like we do" crowd to have customers going in with an issue and a diagnosis. :spoton:
