icer Banned 2,335 Member For: 15y 9m 12d Gender: Male Location: Aspendale, Vic. Posted 18/03/10 08:19 AM Author Share Posted 18/03/10 08:19 AM ok now everythgin seems to work fine bar the car clicking. all the lights etc work no noises etc. I read on another thread that my negative cable was to long so I moved it. but the starter motor still does a clicking noise and doesnt turn over.Anyone near aspendale who wants to be shouted some bears and come have a look?we fitting the plazmaman pipes while we are awaiting some advice Link to comment https://www.fordxr6turbo.com/forum/topic/66893-battery-relocation-help-please/page/2/#findComment-992319 Share on other sites More sharing options...
Guest EGOXRT Guests Posted 18/03/10 09:13 AM Share Posted 18/03/10 09:13 AM Hit the starter with a hammer a few times Link to comment https://www.fordxr6turbo.com/forum/topic/66893-battery-relocation-help-please/page/2/#findComment-992336 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 8m 19d Gender: Male Location: Melb Posted 18/03/10 09:28 AM Share Posted 18/03/10 09:28 AM (edited) err Edited 18/03/10 09:33 AM by Headsex Link to comment https://www.fordxr6turbo.com/forum/topic/66893-battery-relocation-help-please/page/2/#findComment-992344 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 8m 19d Gender: Male Location: Melb Posted 18/03/10 09:33 AM Share Posted 18/03/10 09:33 AM I have connected the nizpro positive teminal to the old positive terminal, then ran it ontop of the radiator where the water overflow pipe runs, and then the middle positive lead is now connecting to the starter motor where there is another positive cable (im guessing the standard power to the old positive battery cable). Pic below (the white one is the nizpro one):(both cables on starter).f*cking FAIL!Your supposed to REMOVE THE OLD POWER LEAD that goes from the STart motor UNDER the engine to the fuse box / OLD BATTERY location.AND THEN your supposed to run the NEW nizpro positive FROM the fuse box, UNDER the engine, to the starter motor, TO the new battery location.Clearly its eveident in your picture that you failed. This is ONE reason why I said LET ME FIT THAT.Remove the nizpro battery Power cable, and Fit the original battery back, Put the original power lead onto the starter motor removing the nizpro stuff. Let me do it Link to comment https://www.fordxr6turbo.com/forum/topic/66893-battery-relocation-help-please/page/2/#findComment-992347 Share on other sites More sharing options...
Mrs Jeturbo Bob the Freaking Builder Donating Members 10,813 Member For: 15y 7m 17d Gender: Female Location: SA Posted 18/03/10 09:37 AM Share Posted 18/03/10 09:37 AM (edited) might have had a better go if your mrs had of fitted it... woulda at least looked hot doing it!!! haha Edited 18/03/10 09:39 AM by Fluffy Mc D Link to comment https://www.fordxr6turbo.com/forum/topic/66893-battery-relocation-help-please/page/2/#findComment-992348 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 9m 12d Gender: Male Location: Aspendale, Vic. Posted 18/03/10 09:39 AM Author Share Posted 18/03/10 09:39 AM I learn little when I pay people to do things....tried it myself and failed obviosuly lol.it is all back to standard airbox is out and normal battery and terminals fitted.car still wont start. checked fuses with multi meter and all seem good Link to comment https://www.fordxr6turbo.com/forum/topic/66893-battery-relocation-help-please/page/2/#findComment-992350 Share on other sites More sharing options...
Mrs Jeturbo Bob the Freaking Builder Donating Members 10,813 Member For: 15y 7m 17d Gender: Female Location: SA Posted 18/03/10 09:41 AM Share Posted 18/03/10 09:41 AM im sure if you asked danny nicely he might show you some things.. maybe let you watch... Link to comment https://www.fordxr6turbo.com/forum/topic/66893-battery-relocation-help-please/page/2/#findComment-992352 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 8m 19d Gender: Male Location: Melb Posted 18/03/10 09:42 AM Share Posted 18/03/10 09:42 AM Check the position of the Power lead on the starter motor.. The starter motor has like a keyway.. If its not properly aligned, the terminal will not sit flush up against the starter motor, and when you attempt to tighten it up, you will break the lug off the starter motor... = NEW STARTER MOTOR (my mate did it)Second of all, There will be a earth point roughly where the ORIGINAL under battery pipe bolted to the engine bay (behind/below the drivers headlight). My guess is 1) you removed it, or 2) you ripped it off when changing the AVO under battery pipe.. Link to comment https://www.fordxr6turbo.com/forum/topic/66893-battery-relocation-help-please/page/2/#findComment-992353 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 9m 12d Gender: Male Location: Aspendale, Vic. Posted 18/03/10 10:20 AM Author Share Posted 18/03/10 10:20 AM so out of all this ill prob need a new bloody starter. all ground cables are were they should be. I can see the under battery one fine.how can I test a starter to see if its gone? Link to comment https://www.fordxr6turbo.com/forum/topic/66893-battery-relocation-help-please/page/2/#findComment-992374 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 5m 16d Gender: Male Location: Dé·jà vu Posted 18/03/10 03:08 PM Share Posted 18/03/10 03:08 PM Anyone near aspendale who wants to be shouted some bears and come have a look?Teddy Bears or Gummy Bears... Link to comment https://www.fordxr6turbo.com/forum/topic/66893-battery-relocation-help-please/page/2/#findComment-992444 Share on other sites More sharing options...
