  • Legacy Donating Member
  • Member For: 22y 4m 11d
  • Gender: Female
Posted
Hi guys,
Just replacing full set of coils and spark plugs, can someone tell me the gap to which the spark plug needs to be for a BA XR6 Turbo sedan.
Thanks
Aly
  • BOOST
  • Moderating Team
  • Member For: 23y 20d
Posted
0.8 if I remember correctly
  • Member For: 17y 8m 19d
Posted
Standard boost = 1mm
Over 8psi = 0.83mm
Over 14psi = 0.80mm
  • 1 month later...
  • Donating doesnt allow you to be an idiot!
  • Member For: 19y 7m 8d
Posted
if your running normal boost but have it gapped to 0.83 from when u were running 10psi, will that affect the running of the car at all Ben?
  • Bob the Freaking Builder
  • Member For: 17y 12d
  • Gender: Female
Posted
on low tune I run .80 gap (9psi) and it runs sweet as!
  • Member For: 18y 4m 18d
Posted
I run a .9mm gap with 11psi, seems to do alright but I have a .8mm set which ill put in next service.
  • Member For: 20y 4m
Posted
It may run a little bit rougher at idle... That's all....
