2MUCHKW Member 350 Member For: 18y 8d Posted 09/10/13 07:57 AM Share Posted 09/10/13 07:57 AM I think your oil is too heavy, and though this may not be the cause of your noise, I have found that you want to stay below 40 viscosity (I run a mix of 30 and 40 weight oil to achieve something around 35)I have found that 50 or 60 viscosity oil makes engine more noisy, as I think not enough oil escapes from bearing journals to adequately lubricate bottom of bores, thus causing pistons to 'slap' from side to side.My 2c worth - Good luck with getting this fixed.Hi Ninka,Noticed your running Cosworth Pistons within your Signiture attached below????What are Atomic's Cosworth pistons like for noise when cold????2002 BA XR6 Turbo, ZF 6 Speed Auto, XFT Tuned 371 rwkw, Nizpro Kit, Atomic Rods, Cosworth Pistons, Walbro Fuel Pump, K&N Pod Filter, 4" SMB dump and 5" cat, 2 x 2.5" SS Quad Tip Exhaust, 'Premium' Brakes w. 5000 rotors, Whiteline Anti Roll BarsCheers Link to comment Share on other sites More sharing options...
Adamfiza80 Member 73 Member For: 11y 28d Gender: Male Location: Newcaslte Posted 09/10/13 11:04 AM Share Posted 09/10/13 11:04 AM Yeah it was timimg chain noise. Car is great now after runin and tune by CMS. Link to comment Share on other sites More sharing options...
2MUCHKW Member 350 Member For: 18y 8d Posted 10/10/13 12:11 AM Share Posted 10/10/13 12:11 AM Anyone running Atomic's Cosworth pistons in their engine?If so how many km's has your engine done and at what RWKW???What is the operational noise of Atomic's Cosworth pistons like at idle?Thanks Link to comment Share on other sites More sharing options...
retro-xr6t Donating Members 95 Member For: 14y 3m 14d Gender: Male Posted 10/10/13 02:15 PM Share Posted 10/10/13 02:15 PM (edited) Hey Simon im running an atomic motor with the cosworth pistons, the motor is relatively quiet at idle but does have some timing chain rattle which sucks.done 3000km and is running 498rwkw Edited 10/10/13 02:16 PM by retro-xr6t Link to comment Share on other sites More sharing options...
