Wenier Legacy Donating Member 1,736 Member For: 16y 8m 8d Gender: Male Location: Christchurch, New Zealand Posted 09/02/10 04:16 PM Posted 09/02/10 04:16 PM Any one sensor in the gearbox could most likely put it into limp mode, and finding which one will be a right bugger. I had a Merc that had real problems with putting itself into limp mode and youd get something done to sort it then sure enough it would happen again. Ended up giving up on the thing as it was sucking too much money.
patmc Inactive Members 1 Member For: 18y 1m 12d Posted 11/02/10 11:47 AM Posted 11/02/10 11:47 AM I had this happen on my BF a couple of times after a sluggish start up.Changed the battery and it never happened again.
Buf-Phoon loitering with intent Legacy Donating Member 13,318 Member For: 23y 1m 6d Gender: Male Location: Zombie Birdhouse Posted 12/02/10 12:45 AM Posted 12/02/10 12:45 AM take the car to TUNEHOUSE. I hear they are the way to go up there in QLD.TuneHouse are in Sydney or is there a TuneHouse in FNQ
bjc Legacy Donating Member 2,823 Member For: 23y 22d Gender: Male Location: Townsville Posted 12/02/10 04:23 AM Posted 12/02/10 04:23 AM I've had the limp mode a few times from overboost (though after it was modified) and never had the D light flashing so maybe that's something for you? Try puting the standard filter back in also as the K&N does flow pretty much free.As most on here have said its a process of elimination so start from scratch, its really hard when virtually no one has had the exact problem.Check those battery cables and earths also like others said.Good luck it with and report back when its resolved
jessiexr6gal Member 9 Member For: 16y 11m 15d Gender: Female Location: Cairns, Queensland Posted 14/02/10 06:05 AM Author Posted 14/02/10 06:05 AM Hey everyone thanks for all your comments and possible solutions... Mechanic had it for the whole week and they investigated ALOT of different possibilities... None of which resolved the problem. So they decided to change the ECU and put a flashtuner on it aswell, gave it back to me over the weekend and it has not happened again! Yay in one way because problem solved, not in another cos now I have to ring him tomorrow to tell him its all ok and pay for the bill!!!
BensXR6T Member 478 Member For: 17y 8m 19d Gender: Male Location: Burpengary QLD Posted 14/02/10 09:25 PM Posted 14/02/10 09:25 PM Good to hear you got it all sorted out. Don't forget to add that trans cooler to make sure the box gets the longest life possible
