Kellar Member 51 Member For: 16y 8m 9d Posted 22/01/10 12:05 PM Posted 22/01/10 12:05 PM Hope some one can help with the following: BA 2003 XR6T Auto no modifications as far as I know, after recently purchasing vehicle replaced coil packs, plugs, fuel & air filters, lubricated boost controller, general check over - no obvious boost leaks, running 95 fuel all seem good - engine performs well, very strong - in particular when cold - EG full throttle flat out when cold - very strong, when engine heats up during a full throttle run the engine will break down anywhere from 3.5 to 5k, which feels like coil pack (that familiar thrrrrrrrrrrrrr)when this happens I obviously back off, then the engine looses all power, has no throttle response, will gradually slow down,(have driven 3 ks like this to get to a freeway exit) while lumping over, if I pull over the engine will lump over, cough, splutter & sometimes stall, weather the engine stalls or it is shutdown, restarting the engine solves the problem, runs fine - although seems a little doughy, until I boot it again - then ground hog day can anyone advise the possible cause?
seventytwo Still have a turbo, it's just on a diesel. Legacy Donating Member 5,368 Member For: 21y 2m 18d Gender: Male Location: The 8th Dimension Posted 22/01/10 12:16 PM Posted 22/01/10 12:16 PM My pick would be valve springs, early models had weak springs and given the age of your car I would say they are definitely on the way out
Kellar Member 51 Member For: 16y 8m 9d Posted 22/01/10 12:27 PM Author Posted 22/01/10 12:27 PM Thanks for the tip, even @ 82000ks?
seventytwo Still have a turbo, it's just on a diesel. Legacy Donating Member 5,368 Member For: 21y 2m 18d Gender: Male Location: The 8th Dimension Posted 22/01/10 12:40 PM Posted 22/01/10 12:40 PM YupDo a quick forum search, there is plenty to read on the subject
davidald Me Legacy Donating Member 360 Member For: 19y 5m 28d Gender: Male Location: Adelaide Posted 22/01/10 01:23 PM Posted 22/01/10 01:23 PM Amazing how often there cn be trouble after changing the coil packs etc. Was there something wrong with the old ones? Check they are connected properly and not faulty.
CCCC miso xr6 Legacy Donating Member 317 Member For: 17y 9m 16d Posted 22/01/10 03:19 PM Posted 22/01/10 03:19 PM check fuel filter
robbo k Member 414 Member For: 18y 5m 18d Location: Wollongong Posted 23/01/10 08:43 AM Posted 23/01/10 08:43 AM I cant believe u put the boot into it stone cold.... that's just asking for something to go wrong
our06t Mmmmm......BOOST Member 3,135 Member For: 19y 4m 28d Gender: Male Location: central coast Posted 23/01/10 09:43 AM Posted 23/01/10 09:43 AM (edited) I have bought a set of coils only to find one was dodgey straight out of the box , other than that double check all the coil fitments and wiring.and yeh was the problem there before you changed these partsanother maybe big maybe is the o2 sensor ,the car runs on set program until it warms up then switches over to using the o2 sensor etc Edited 23/01/10 09:46 AM by our06t
Kellar Member 51 Member For: 16y 8m 9d Posted 23/01/10 10:02 AM Author Posted 23/01/10 10:02 AM I cant believe u put the boot into it stone cold.... that's just asking for something to go wrongI do not boot the engine from stone cold, cold means temp gauge needle @ 1/4 op temp on this gauge for this is just below 1/2
Kellar Member 51 Member For: 16y 8m 9d Posted 23/01/10 10:04 AM Author Posted 23/01/10 10:04 AM Sorry should read - I do not boot the engine from stone cold, cold means temp gauge needle @ 1/4 - full operating temp on this gauge = just below 1/2
