Xm coupe Member 24 Member For: 19y 7m 16d Posted 30/11/09 02:09 AM Posted 30/11/09 02:09 AM (edited) Hey guys got my car lowered on the weekend. SL in the front and SSL in the rear. I havent fitted a camber kit at yet and am running 245/30/20 (93W) all round.When they lowered it they gave it a wheel allignment but I found it is pulling to the left. I took it back and the guy said cause they are wide tires it is probably tracking, but I know what tracking is and this isn't tracking, its a definantive pull to the left. They had alook and said it aligned correctly. Any body else had a similar problem? Edited 30/11/09 02:10 AM by Xm coupe
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 18y 3m 13d Gender: Male Location: Earth Posted 30/11/09 02:20 AM Posted 30/11/09 02:20 AM Nope. I made sure I got the wheel alignment figures before I changed my springs so as if needed they could be reset back to the original alignment as I know this setting doesn't pull or wear tyres.
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 25d Gender: Male Location: SW Sydney Posted 30/11/09 02:33 AM Posted 30/11/09 02:33 AM There is a chance its not the alignment, more the Steering wheel input isn't correct. Get them to check that - a very common thing for us here...
Xm coupe Member 24 Member For: 19y 7m 16d Posted 30/11/09 02:42 AM Author Posted 30/11/09 02:42 AM Yeah the steering wheel is off centre slightly but it more when I let go of the steering, even if the car is tracking striaght, once I let go instead continueing to tracking straight it will pull to the left every time.
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 25d Gender: Male Location: SW Sydney Posted 30/11/09 03:57 AM Posted 30/11/09 03:57 AM Could be a toe adjustment setting too, fairly common thing. Too bad you aren't around Sydney, we'd fix it for you!
falconXR6T Member 128 Member For: 23y 5m 17d Posted 30/11/09 06:01 AM Posted 30/11/09 06:01 AM when I had mine lowered sl/ssl it was pulling to the left alot, got told that I need a camber kit, I just took it to another place and got the wheel alignment and it was all fixed.
Xm coupe Member 24 Member For: 19y 7m 16d Posted 30/11/09 11:00 AM Author Posted 30/11/09 11:00 AM (edited) Could be a toe adjustment setting too, fairly common thing. Too bad you aren't around Sydney, we'd fix it for you!Senna,I am in syd, you may recall I came on a cruz with you guys in July I think, in my WRX. Where abouts are you at, I might bring it around for you to have a look at. Edited 30/11/09 11:01 AM by Xm coupe
Dillz Three pedals are better then two.. Legacy Donating Member 15,637 Member For: 19y 4m 6d Gender: Male Location: Melbourne Posted 30/11/09 11:06 AM Posted 30/11/09 11:06 AM I know my camber is f*cked up after slamming mine, does this happen in later models?
o2sucka Member 242 Member For: 17y 2m 1d Gender: Male Location: Sydney - Campbelltown Posted 30/11/09 12:17 PM Posted 30/11/09 12:17 PM Make sure you go see Pat he will have it fixed for ya. They know there stuff there. I had mine lowered by these guys and they did a great job, no pulling either side and the steering wheel was off centre and they made sure it was fixed before I left.No issues at all.
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 25d Gender: Male Location: SW Sydney Posted 30/11/09 09:54 PM Posted 30/11/09 09:54 PM Senna,I am in syd, you may recall I came on a cruz with you guys in July I think, in my WRX. Where abouts are you at, I might bring it around for you to have a look at.Ah ok, no probs. We are at 129 Coreen Ave Penrith. If you would like to give me a call I can book you in. CheersPat02 4721 2112
