gregor Member 459 Member For: 18y 1m 7d Posted 28/11/09 09:48 PM Posted 28/11/09 09:48 PM from what ive seen on here it isnt that simple they are way more advanced than the 4 speed. do a search for zf transmission cooler on here. If you do attempt it make sure you post your results. I'd love to do it for track days.
BFHOON Legacy Donating Member 1,932 Member For: 20y 6m 4d Gender: Male Location: nsw Posted 30/11/09 03:10 PM Posted 30/11/09 03:10 PM if he does it like his mate it will be a under battery mounted cooler with a fan mounted on it running a digital fridge thermo controler.
R_Spec_Matt Legacy Donating Member 120 Member For: 17y 3m 28d Gender: Male Location: Sunny Coast QLD Posted 01/12/09 04:06 AM Author Posted 01/12/09 04:06 AM yeah u got it right mate
ScatterBrain Legacy Donating Member 316 Member For: 17y 3m 26d Gender: Male Location: Brisbane Posted 01/12/09 08:57 AM Posted 01/12/09 08:57 AM I'm fitting a oil cooler to my zf this weekend, so Ill tell you how it goes.
R_Spec_Matt Legacy Donating Member 120 Member For: 17y 3m 28d Gender: Male Location: Sunny Coast QLD Posted 03/12/09 12:35 PM Author Posted 03/12/09 12:35 PM I'm fitting a oil cooler to my zf this weekend, so Ill tell you how it goes.yeah cool awesome hope it goes all well
R_Spec_Matt Legacy Donating Member 120 Member For: 17y 3m 28d Gender: Male Location: Sunny Coast QLD Posted 22/12/09 03:14 AM Author Posted 22/12/09 03:14 AM You don't need valve springs dude.Get:- Wastegate ported, 38mm flapper valve and a 12psi or 15psi actuator- 4" airbox- Fuel pump- 60lb injectors- 4" dump and a good catyeah mate where is a good place to get these done was told there is only 1 place in aus to get turbo done in mel somewhere like turbo something the place is called ??? can any1 tell the number..also is 38mm flapper big enough or bigger is better ???
ratter Member 6,793 Member For: 20y 4m 1d Gender: Male Location: @ my laptop Posted 22/12/09 07:24 AM Posted 22/12/09 07:24 AM there are plenty of places that can mod the turbo wastegate, some better than others, start with your tuner first
R_Spec_Matt Legacy Donating Member 120 Member For: 17y 3m 28d Gender: Male Location: Sunny Coast QLD Posted 22/12/09 12:04 PM Author Posted 22/12/09 12:04 PM yeah maybe so but not where I live I live on the sunshine coast QLD my tune was at redcilf dyno and all he says is u carnt go much more than I already have without blowing my engine and all I have atm is 292 rwks
tab Sucker Moderating Team 32,303 Member For: 22y 5m 3d Gender: Male Location: Brisbane Posted 22/12/09 09:48 PM Posted 22/12/09 09:48 PM Go a bit further south and you should be right.
Casey Spencer Member 43 Member For: 16y 11m 16d Gender: Male Location: qld Posted 28/12/09 07:28 AM Posted 28/12/09 07:28 AM A good start is how much money do you want to spend.process west surge tank are cheap and good for the power.60lbs injectors .exchange turbo housings are pretty cheap (labour is the killer).I have a 3.5inch split dump pipe sitting at work, flows as well as a 4inch.battery relocation is easy you could put it in a battery box in the boot, plus you could do it yourselfrapid do a nice four inch intake pipeXtreme Ford Tuning do a exchange 6sp zf good for 500kw+
