04/11/09 02:00 PM04/11/09 02:00 PM #1 can anybody tell me what fuse to remove to stop the panic button from working??Dam thing keeps going off and I have tried changing the batteries in the remotes but nothing seems to work. Any help would be great or I will just go through the fuses until I get it to stop.CheersRhys
04/11/09 10:36 PM04/11/09 10:36 PM #2 I don't think there is a fuse for it, it uses the horn. You could take out the horn fuse if you want a car with no horn.
04/11/09 11:03 PM04/11/09 11:03 PM #3 which is also classified as a fail for a RWC....(no horn that is)
05/11/09 04:54 AM05/11/09 04:54 AM #4 My horn decided to start going off at 3am one morning.Thought that something was up, took out the relay for the horn etc.Ended up getting a flat battery 2 weeks later.Maybe that's the problem. Apparently the horn sounds when you battery is going flat.Just another idea if you battery is about 3-4 years old.
05/11/09 07:01 AM05/11/09 07:01 AM #5 Ive got the same problem, mine seems to go off early in the morning. Ive got a dry cell excide battery, but it has been run flat a couple of times so maybe I need a new one.
05/11/09 09:53 AM05/11/09 09:53 AM #7 I have the same problem aswell, the only thing I can put it down to is the remote gets some moisture inside the remote on the circuit board. I wipe it off and it seems to stop it
05/11/09 09:56 AM05/11/09 09:56 AM #8 Try pulling the batterys out of your remotes and see if you get a good nights sleep. Remotes are common for getting moisture as mentioned so pull the batterys out and see what happens....
08/11/09 09:29 PM08/11/09 09:29 PM #9 As already mentioned, my panic button went off after I took my remote into the bathroom when I was having a shower. Then the remote didn't work as well, and occasionaly would cause the panic horn to go off. Pulled the remote apart and cleaned/dried out all the moisture, now she's good as new.
08/11/09 10:12 PM08/11/09 10:12 PM #10 I had this happen the other day, was a flat battery because the car has been sittin for a couple months, u probably just need a new battery
