  • Member For: 15y 9m 22d
Cheers for the support.
Yes t04e turbos
Yeh turbo's do sit pretty close to the overflow bottle, but im gunna put a catch can instead, and run the hoses into a different spot so they dont interfere with the waste gate actuators. Got a heap of fibreglass wrap to go round the manifold and dump pipes try and keep the heat down a bit, thinking about putting aluminium barriers up to protect the heater hoses and hydraulic clutch line.
Gunna control boost with a dual stage electronic boost controller. Waste gate springs are both set to 8psi but with lowereded compression and possibly forged pistons and rods will hope to run upward of 14psi. My understanding of the boost controlling is once manifold pressure reaches the boost I want both gates should waste equally to regulate to desired boost, even if one turbo is making 8psi and the other is making 6psi, once maifold pressure reaches 14psi they should both regulate equally.
Currently got an old sigma on lpg as my daily driver while im working on the ute, hoping to get a good bit of work done in the next few weeks, ill update progress as it comes.
Any info people want to know just ask, im more than happy to share my success and failures. (more failure than success so far)
  • 4 weeks later...
  • Three pedals are better then two..
  • Member For: 18y 1m 17d
I guess Patty was too slow, lol.
Will be interesting to see but I still stand by my original comments of it being of any benefit over a single.
Apart from the WOW factor of course.
put the battery in the boot relocate you coolant res and power steer res it will give you much more room,
what size dump pipes will you run. you could almost run a twin 3inch into twin cats in 4inch,
it will be good to see what power she will make :beerchug:
  • 3 weeks later...
  • Member For: 16y 3m 18d
WOW.. looks a treat mate... Good luck with the build.. May need to invest in a parachute or a large anchor to pull up.... Or just boost all the way.. look forward to the finished product :3gears:
