phoonme Member 8 Member For: 17y 5m 26d Posted 21/08/09 10:17 AM Posted 21/08/09 10:17 AM hey guys, my car is a stock ba xr6 turbo 5 spd manual. now I fitted boost guages a while ago just so I knew if I running the right amount of boost even though its 4 psi from factory. but today it came in handy. if you punch it and it goes to hit boost it will go to 2psi and then drop back to 0 but then later on it came good and was working fine again. its like the actuator is keeping the waste gate open. does this mean that its broken and it will need to be replaced. do I upgrade to a bigger one? also where can I get a new one?regards Jarrad
trevs Member 781 Member For: 19y 5m 5d Gender: Male Location: balmain Posted 21/08/09 10:24 AM Posted 21/08/09 10:24 AM could be any number of things but start here http://www.fordxr6turbo.com/forum/index.php?showtopic=31329 cheers trev
Redback Banned 236 Member For: 17y 3m 15d Gender: Male Location: Blacktown NSW Posted 21/08/09 09:42 PM Posted 21/08/09 09:42 PM Hey Jarrad,Could have a sticky actuator.You could have a smoke test done on all your intake to ensure that you dont have any leaking pipes or joins. Just make sure you check all your hoses and pipes for leaks and make sure your clamps are all tight. Also try servicing the actuator solonoid. If you need an actuator I have one lying around for $50 (standard one), otherwise you can get a 12psi for around $140 but will need a retune. Cheers.
phoonme Member 8 Member For: 17y 5m 26d Posted 21/08/09 10:35 PM Author Posted 21/08/09 10:35 PM 50.00 sounds great. including postage or put that on top??
sikhabib Inactive Members 1 Member For: 17y 5d Posted 23/09/09 06:34 AM Posted 23/09/09 06:34 AM sorry phooneme I dont mean to highjack but....redback, if phooneme doesnt end up buying the actuator can you please let know know as im after onealso phooneme if you find your old actuator is ok after trying the new one ill buy it off youcheersronny
The_Bogan Legacy Donating Member 881 Member For: 19y 5m 23d Gender: Male Location: Brisbane, Queensland Posted 30/09/09 10:17 AM Posted 30/09/09 10:17 AM it doesnt sound like a faulty actuator to me.it sounds as though you may have a small boost leak or crack in a rubber join somewhere.possibly a crack in your manifold or loose turbo boltsas the boost pressure increases, the crack will become wider... could be a reason why you lose boost towards the end.or if it is crack in the manifold.... as the heat increases in the manifold the metal will expand making the crack slighlty larger and causing more of a boost leak..I would be going over your pipework and inspecting hose clamps and rubber joins first.
ETM Member 1,194 Member For: 19y 6m 13d Gender: Male Location: syd south Posted 30/09/09 10:01 PM Posted 30/09/09 10:01 PM I do leakdown testing of turbo systems if you are local to me (wollongong area) I can sort your problem out.
