  • Member For: 17y 10m 7d
Posted
tonight I tried to remove a blow globe . the one from the boot. problem is when I took it out I tried to put the housing back in the slot and I think the black wire touched the parcel tray underneath ( actual body) then a few sparks flew. problem now is no interior lights or reading lights will work except fot the ignition ring. :howbig: have I blown a fuse or something? if so where is it located?
any help would be appreciated
cheers
nick
  • Sucker
  • Moderating Team
  • Member For: 22y 5m 12d
Posted
Sounds like it. All the interior fuses are under the driver's side vent, pull the cover off and there should be a legend stuck on it so you know where to start digging.
  • Legacy Donating Member
  • Member For: 21y 3m
Posted
For some reason ford decided not to put a fuse legend on the fuse cover, so you will have to check your manual.
  • Sucker
  • Moderating Team
Posted
Well there you go...I'm certain my BA did though. Good work Ford, hope that $0.20 was worth saving. :msm:
  • Damn You's A Sexy Chich
  • Member For: 18y 7m 21d
Posted
Well there you go...I'm certain my BA did though. Good work Ford, hope that $0.20 was worth saving. :omg:
They spent that extra 20c per vehicle on unmatched after sales service and support...
