Stuttering Under Load, Help With Diagnosis
Featured Replies
#11
Ultra Tune LMAO
#12
  • Author
Dont UltraTune run the same computer/software as Ford would have used?
#13
Is your car edited?
if so get your tuner to alter/remove your torque tags
#14
  • Author
Nah mate is stock.
#15
the white goo is suppossed to be there senna .dont wipe it away it's silicon grease to stop moisture getting in between the plugs and coil packs
#16
hmmm, never had it on my coils, never had an issue with em either - well I tell a lie I had a coil die once, but never again, the more power we've cranked out of it the less issues the ignition system has had!
#17
Hey berzerka - mine just started to do the same thing, did you end up fixing the problem and did you change the plugs only or the plugs and the coils?
#18
  • Author
Only changed spark plugs but not coils, and yes it pretty much fixed it except when floored in first gear. Other than that, yeah its fixed
Going for a custom tune very shortly, so, will see what the tuner says, and how it come out after tune.
Recently Browsing 0
