May 11, 200917 yr #1 Hey guys,So I was on my way to work this morning and I went to gun it and all of sudden theirs very little power in the engine after 3000rpm? it feels like a boost problem and all it does seems little like if you hit rev limiter but bumps lot faster? hard to describe :/ The car is pretty much stock, part from K&N filter 120000Kms on the clock BA turbo 2003...Any help on what the problem might be urgent as it every day car?
May 11, 200917 yr #3 from how you describe the problem it could be coil packs or plugs.checking all of your clamps on the intercooler piping wouldnt hurt either
May 11, 200917 yr #5 Author might sound silly but its not traction control is it.HEHE.. nah tried that.. but its sort of the same affect that the engine has...Also it's now starting to have a miss when you start it up and idle.Would loose bolt or something do this type of problem? I'm going to see if I can take it to a ford mechanic ASAP.
May 11, 200917 yr #7 Could be coils, could be spark plugs.Did anyone think about the gearbox??Could be an issue there if it's coming up against a stone wall. Like if you rev it in neutral it'll only do 3000rpm.Long shot.
May 13, 200917 yr #9 my 2002 BA xr6t had the same problem around the same amount of Km come to think of it.
