April 12, 200917 yr #1 ok well I went on a big drive but on the way home I notice my gauges,my premo sound and headlights are dimming my battrey is in the boot and it is earthed at the back of the car I herd that I should run the earth back up the front of the car is this rite oh and I get a bit of a wind as well and worse when a/c is on......05 xr6t Edited April 12, 200917 yr by wilbaz
April 12, 200917 yr #2 Id be checking all the fittings. Your alternator could be on the way out or the battery
April 12, 200917 yr #6 start the car up wilba and then put a multimeter across the terminals - it should read 13.2 - 14.8 volts - any higher she stuffed any lower she stuffed
April 12, 200917 yr #10 well worth checking the earth mate, a bad earth can cause all sorts of issues
