  • Member For: 23y 3m 26d
Posted
hi all
just a quick 1
I got a XR6T ... full standard besides cosmetic mods
I hav a problem when I give it to it the car hits 18psi and sounds like it is missing
and the car restriccts itself
I have heard diff ppl tell me diff things like
the cat convertor has collapsed and blocked the exhaust up
the actuator?
any help would b appreciated
  • Cryptic Clothing Company
  • Legacy Donating Member
  • Member For: 18y 2m 28d
Posted (edited)
yeah, id be gettin that tuned asap.. and I wud keep off boosting it. when I did my intercooler kit and was on my way down to get it tuned, I cudnt help my self to put my foot down, and she hit 27psi.. goes to show how much airflow everything is restricting
Edited by typhoon_freak
Posted
I tryed gettin it tuned ... and the place sed they can set it at 12psi
but it keeps goin up to 18 on its own
there the 1s who sed its the exhaust
Posted (edited)
I thought they wud b able to control it.. if its going crazy like that, maybe do the flapper mod on the turbo,
  • Member For: 18y 8m 20d
Posted
actuator is basically a spring in the turbo that holds boost. sounds like your wastegate is jammed champ, so you cant bleed off excess boost.
Posted
price depends on what you can and cant do yourself. its nothin major, but stay off boost. if it were mine I would take the turbo off, inspect and see what needs doing. then replace the actuator with an 8psi one. then a tune.
  • Member For: 19y 3m 13d
Posted
The vehicle is totally stock therefore if it is overboosting to 18psi, then it most prob could be the actuator, which opens up to allow excess boost out , whereas as in your situation your flapper is staying shut therefore building up huge boost and going into limp mode...also be careful that its not pinging, and it would also be running very lean at those boost levels...so bad that you could be in for a bang....stay off slamming the throttle and take it to a worshop to suss out the actuator...this isnt the first time ive heard of this happening.
  • Member For: 18y 7m
Posted
Is the 12psi tune still on the car, or is it back to standard tune?
Probably unlikely, but check the hose that comes off the front of the turbo and connects to the boost solenoid. If that's off it will boost well past standard. Click here that thread tells you how to clean the solenoid, use that as a guide to find the hose I am talking about. Follow it from the solenoid and it should be attached to the front of the turbo.
Good Luck.
