Scrotus Member 156 Member For: 18y 1m 29d Gender: Male Location: Adelaide Posted 09/03/09 11:04 AM Author Posted 09/03/09 11:04 AM There is minimal play, feels normal. Is there anything else that is worth replacing while the comp wheel is out? The turbo has 80 000km on it. Might be worth upgrading the Actuator?
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 19y 1m 22d Gender: Male Location: Perff, WA Posted 09/03/09 11:35 AM Posted 09/03/09 11:35 AM Fark, well I was right eh? suppose it's lucky you found it sooner than later!?hope it's not too expensive for ya mate.
Scrotus Member 156 Member For: 18y 1m 29d Gender: Male Location: Adelaide Posted 09/03/09 12:06 PM Author Posted 09/03/09 12:06 PM I was hoping you where wrong : )
freeze_dk I am dissatisfied with my current employment situation Legacy Donating Member 8,610 Member For: 20y 13d Gender: Male Posted 14/06/09 09:53 AM Posted 14/06/09 09:53 AM my car started doing this noise tonight.. it happens at around 2k + revs,, not as loud as the vid this guy posted but u can hear it in the car.. it wasnt doing it last night either.. 2 days ago I changed the silicone joiner off the turbo because it had a split in it.. when I was reversing into my garage before on release of the throttle the car stalled twice.. please tell me this is just a boost leak and not a bent fin
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 20y 5m 8d Gender: Male Posted 14/06/09 10:16 AM Posted 14/06/09 10:16 AM One way to find out, I would be checking your comp wheel.
Ricks_Xr6t Member 101 Member For: 17y 8m 24d Gender: Male Location: Karratha,W.A. Posted 14/06/09 10:56 PM Posted 14/06/09 10:56 PM Sounds like an AU 4speed,lol.
Ricky N Member 93 Member For: 17y 6m 19d Gender: Male Location: QLD Posted 15/06/09 04:39 AM Posted 15/06/09 04:39 AM You can't just put another compressor wheel on there. It will need to be torqued down and straitened and VSR balanced at the very least. Most places will not VSR balance the turbo unless it has a new bearing pack put into it.The other thing is unless something has been sucked through it is probably the turbine head has drooped and cursed the turbo to be out of balance. The unbalanced harmonics would have caused the comp wheel to grab the cover and bend the blade.You may get very lucky and it only needs a comp wheel and balance but more than likely you are going to need a new Compressor wheel, bearing pack and turbine. The comp housing may need to be clened up as well.A turbo shop it going to have to do the repair of the actual turbo.If the turbo needs a new turbine try to get an Inconel turbine. This will help prevent future turbine head droop and fatigue that leads to turbo failure.If Garrett doesn’t have them (As they are pretty rare) and you’re local turbo shop is unsure where they can get an Inconel Turbine for a GT35R. MTA (AKA: MR Turbo Australia) has replacement 713c Inconel GT35R turbines. If your Your local turbo shop cann't find one they will be able to get the part from them.The standard Garrett GT35R’s have a GMR turbine.
freeze_dk I am dissatisfied with my current employment situation Legacy Donating Member 8,610 Member For: 20y 13d Gender: Male Posted 15/06/09 08:36 AM Posted 15/06/09 08:36 AM stripped the piping again today,, fins on the turbo are fine.. on closer inspection the loud whine is coming from the power steering rack
straughsberry Legacy Donating Member 1,846 Member For: 19y 1m 23d Gender: Male Location: Broady, Melbourne Posted 15/06/09 09:14 AM Posted 15/06/09 09:14 AM Sounds like an AU 4speed,lol.Ahh you refer to ye olde taxi planetaries =)
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 20y 5m 8d Gender: Male Posted 15/06/09 09:18 AM Posted 15/06/09 09:18 AM You can't just put another compressor wheel on there.Bull sht... I did 3 years ago and ive been running between 15 -17 psi no dramas.Just like you need a turbo timer hey :laughrolling:
