Advice Please
Featured Replies
#1
So.........I should be here writing about how I've just had new seimens injectors, a walbro and valve springs installed and now running 270rwkw and its sweeeeet! :biggthumpup:
Well it was for two days however today while cruising over to a mates house (and just cruising I was) my car decided to just die out of no where. :blink:
I pulled to the side of the road and tried to start it again, no go!
Now, I had let the fuel get lowish, the trip meter said I had 75km left......hang on maybe the new pump is sitting a little higher and there is no fuel getting to the pick up. So after getting some more fuel in a jerry and going back and filling up I tried to start it again. Bingo straight away it started, idled for 5 seconds then died again. hmmmmm tried to get it to start again for the next 5 mins but no go :huh:
The question I now would like to ask is - when I turn the ignition on, shouldnt I be able to hear the fuel pump whining, ready to start? I can't actually hear the pump at all, though when I first got the ute back I noticed that the walbro seemed noisier than the factory item.
I will ring the workshop who installed it tomorrow, but would like to know if my thinking is along the right lines.
btw. I have checked the fuel pump relay etc with my multi meter and it is fine so I can assume that power should be getting to the fuel pump.
any suggestions would be great
cheers
Sean
  • Replies 21
  • Views 1.7k
#2
did you replace the fuel hoses when you changed the pump?
#3
I think you're on the right track mate, get the pump checked out asap. Did you buy the pump yourself or did the workshop supply it too?
#4
Bingo straight away it started, idled for 5 seconds then died again. hmmmmm tried to get it to start again for the next 5 mins but no go :biggthumpup:
that is definately a lack of fuel supply causing the problem, check for faulty wiring, kinks in fuel hose both externally and internally, clogged fuel filter, pump failure
#5
  • Author
Hi guys thanks for the quick replies.
Judd, I had a workshop do the work so I'm not too sure exactly what they have done when installing.
Senna, The workshop supplied and fitted the pump. I was going to buy a pump myself, but decided to let them supply it to hopefully avoid something like this happening as I've heard theres a few non genuine pumps going around. I could have purchased one $80 or so cheaper but thought the warranty from the workshop was worth more!
ETM, yeah my gut feeling is that there is no fuel getting to the engine.
I have taken the tub out and was going to do some investigating, but dont have the time atm. I reckon its the pump though, only because I can't hear it priming up or anything when I turn on the ignition..............just not sure if I'm imagining hearing it before?
Cheers
Sean
#6
  • Author
Oh btw, I've towed the car home, it will not start at all.............just in case you thought it was a temperamental prob.
#7
Possibly a bad join on the wiring on the fuel pump, or incorrect (non submersible hose) hose fitted to the pump.
:biggthumpup:
#8
you can hear my walbro prime when I start it. The only reason I said about the hoses is that if you dont use submersible fuel hose it can bust.
#9
  • Author
Yeah thought it could be heard on start up.
I would think that the right hose has been used as it is a reputable workshop.
atm I'm thinking that it is either a faulty pump or as ratter said, a bad connection in the wiring somewhere.
I'll let you guys know when its sorted.
Lucky its not my daily!
Cheers
Sean
#10
  • Author
Hey guys, all sorted. had the mechanic come over on tues night and we pulled the pump out and sure enough it was 'seized'. Picked up a new one tonight (free of charge of course) and installed it............and its all good again! Went for a strap, damn these things are good with a litlle bit of tuning :spoton: haha!
thanks for the responses! This forum is a gold mine of information, even though I post very little I have been floating around reading them for the past 4 years and have learnt so much!
Cheers again!
.............now for some more mods :beerchug:
Cheers
Sean
Recently Browsing 0
