5k Build Up
Featured Replies
#1
hey guys,
I am about to do some mods, and have got really mixed opinions from mechanics, so if you could give me your ideas on what to do to my xr6t mkii 04 manual, I have a 5k budget and what sort of power roughly would I make, the car is dead stock atm
cheers guys!!!!!!
#2
Need more info on the car mate... BA, BF, MK1 or 2 all are different as to what path to take..
#3
firstly the clutch will need doing that's like $2k already! u can prob get valve springs, injectors, cooler, tune, bash the cat....your laughin 300rwkw.
Edited by XRDOSE
#4
04 Mk11 would be a BA 5 speed wouldn't it :beerchug:
If so then throw the 5k at a 6 speed and your away.
#5
Nah, Mk2 is T56 dillz
ADEM - 5K can go a long way, but put aside around $2500 for a good Clutch and supply and fit Valve Springs. After that you will need a Flash Tuner, bigger injectors, a Big Cat (4" min.) and then you should look at a better Intercooler. Just make sure you upgrade the brakes somehow - Slotted Discs and some better pads will make a big improvement - there's no point going faster if you can't stop!
:beerchug:
#6
BA mk2's had the 6 speed manual.. I had one :)
Back to your question.. as mentioned earlier, u will need a clutch as the standard one is no good for much more than standard power. Probly goin to need valve springs as well. The 2nd air intake ( typhoon one). Either gut the cat or get a high flow one ( at least 3.5"). Remove the centre muffler as well, this will change the note of the car as well as help with flow. Injectors, flash box and also an intercooler(2nd hand possibly). That would see you around 5K, depending on where u go etc..
#7
In an 04? I thought they started 05, my bad.
that's what I like about this site, ya learn stuff.
Edited by Dillz
#8
My 05 BA MKII is a 5speed.. :beerchug:
#9
N/A BA Mk2s are 5spd, Turbos are 6 spd. The BA Mk2 started in October 04
#10
Ahh.. Fair enough then :)
Recently Browsing 0
