  • Member For: 23y 8m 2d
Posted
Im looking at a brand of cat that is 100 cpi .The 4.5" body flows around 720 cfm(claimed)where the 5.5" one flows over 800cfm is the 4.5" one enough for me if im chasing around 300rwkw??
How do you really know that they are flowing what they say its flowing without buying it and getting it tested yourself.
  • Legacy Donating Member
  • Member For: 21y 3m 3d
Posted
The inlet/outlet size will affect flow as well as body size. If you get a 4.5" body with 100cpi on a std BF dump that will be good for 300 on 12 - 14 psi (depending on other mods). Ba dump will restict slightly due to the twin exit.
Don't worry about testing. 100cpi is the latest and greatest in cats.
Posted
thanks for reply
  • 2 months later...
  • Member For: 17y 11m 9d
Posted
well I found a cat with a 3 1/2 inlet/outlet and the body size is 3 1/2 is that good or should the body be bigger here is that site www.pcpa.com.au thanx
  • Member For: 19y 6m 28d
Posted
so its a straight bit of pipe with a cat cell in it, it would flow pretty badly compared to one with a 5" body.
Posted (edited)
rite so I take it im better off getting a xforce or sumthin like that.so bigger the body the better?
Edited by wilbaz
Posted
yeah, imagine the cat cells take up 30% of the area of the pipe is 3.5" all the way through the cat section will flow 30% worse than the rest of the exhaust system. If the section with the cat cells is say 5" then it obviously has enough extra area to make up the difference and flow as much as a bit of straight 3.5" pipe
Posted
thanx heaps mate :Doh:
