September 29, 200818 yr #22 how do I know which fuse I blewI have a bunch of fuses for the electricals..Open the fuse box, pretty sure it has a diagram on the lid with what does what. If not it's in your manual.
September 29, 200818 yr #23 The place where you bolted the horn too has to have a good connection to the body of the car (bare metal).The bracket/bolt that is on the horns is used as the earth for the horn. I bet that's your problemo mate Edited September 29, 200818 yr by XF Falcon
September 29, 200818 yr #24 Author You had a few hiccups but all in all a top effort thanks mate.. If my radiator continues to leak, I might try and see if ford can replace it under warranty by saying it cracked and I tried to patch it up so I could bring it to them safely .. =]Open the fuse box, pretty sure it has a diagram on the lid with what does what. If not it's in your manual.Kewl thanks for the advice. I'll have a look at it first thing in the morning. The place where you bolted the horn too has to have a good connection to the body of the car (bare metal).The bracket/bolt that is on the horns is used as the earth for the horn. I bet that's your problemo mate LOLI mounted mine exactly how this picture shows its mounted they were working perfectly .. I had them bolted on nicely but as soon as the front bumper went on.. they just dont want to work =/I'll check this fuse thing out first
September 29, 200818 yr #25 Hmmm well my horns are still in my boot, cause they didnt work after I tried to fit em back after the cooler went in.. Think I'll have another go..
September 30, 200818 yr #26 Author took my car for its 1st spin just then, after filling up the coolent tank with water (temporarily)and my " Malfcuntion Indicator Lamp" which looks like the TEA pot shape .. stays onin the manual it says that " this light will only remain on if the vehicle is no longer operating withing the emission regulations ... fault has developed that will damage the catalytic converter"IS that normal since I've fitted this high flow intercooler on without a tune.. ?to me it looks like my car is just telling me that its no stock anymore and detects the upgrade.. I may be wrong but does anyone know for certain..?oh and to the positive side, I have a loud huge flutter and in 1st gear , foot to the floor at around 4000rpm.. the car goes sideways and has a tiny bit of axle tramp =]thanks.
September 30, 200818 yr #27 I wouldn't be driving it too hard without a tune mate. That's just asking for trouble if she's running lean!
September 30, 200818 yr #30 if its a nice neat hole you drilled in the radiator a screw and a bit of thead sealer should do the trick !!
