August 31, 200818 yr #1 Hi Everyone,Just a quick question, I wanted to spray my calipers, I have the correct paint etc, but just wondering, does anything special need to be done due to the ABS?Or can I pull them off, spray them and put them back on without hassles?ThanksSteve
August 31, 200818 yr #2 yep u can pull em of no hasels matejust clamp the lines so the fluid doesnt leak out tom muchand make sure u bleed it properly after to get the air out.
August 31, 200818 yr #3 I sprayed my callipers on my old car without taking them off. Just remove the bolts and take the caliper off and use a coathanger to make a hook to hang them up. Mask the brake lines using foil and masking tape, also mask the piston. Put newspaper in the wheel arch and spray away.
September 6, 200818 yr #5 ive been thinking about this also, ive got the pbr upgrade, my car is phantom, and I was thinking bout painting them purple, what sort of paint did u guys use??
September 6, 200818 yr #6 Dont really think purple coloured calipers would be noticed on a purple coloured car. Try something else that stands out.I.B.
October 2, 200818 yr #7 ive been thinking about this also, ive got the pbr upgrade, my car is phantom, and I was thinking bout painting them purple, what sort of paint did u guys use??I'd like to find out also what paint is used for the calipers? thanks in advance
October 2, 200818 yr #8 Strangely enough its called Brake Caliper paint, your can pick it up at any auto store.
October 30, 200817 yr #10 I'm doing mine this weekend mate if all goes well ill let ya know and we can do your car together
