  • ORSM Ford Cruisers!
  • Legacy Donating Member
  • Member For: 21y 4m 9d
Posted
Heres something that you wont see too much of.
name="allowFullScreen" value="true"></param><embed src="
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="349"></embed></object>&">
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="349"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
270kmh Speedo and 8000rpm tacho on an XR Cluster.
Posted
I havent tested shift alert functionality on a BA2 cluster. But I am sure you can enable it on BA2 onwards. It requires a reprogramming of the eeprom inside the cluster to enable it.
Matt
  • RUS531
  • Member For: 20y 1m 19d
Posted
ahh sweet so how do we do that.... tuner or a turned on ford tech?
  • BOOST
  • Moderating Team
  • Member For: 23y 1m 4d
Posted
Come on tell us.. We'll be your best friends
Posted
You need to de solder the eeprom reprogram it and re solder it. I can do it in about 20mins.
The only person that I know that would be able to do it is myself and most likely VDO.
Matt
  • BOOST
  • Moderating Team
Posted
To hard basket by the sounds of it
  • Member For: 18y 1m 26d
Posted
looks like police cluster, I also have rpm to 8 though think speedo is 260. Also have P on the lcd / or SC if push trip button.
Posted
If its anything else but a FPV you will have a 7000rpm tacho.
The only thing different on a Police car is that they have Police Mode enabled on the cluster , which yes I do have turned on in mine.
Matt
