  • Legacy Donating Member
  • Member For: 18y 11m 10d
Posted
Hi guy's just installed the 3.5" metal cat and had a engine fault come up. I checked a engine fault code which came up saying the cat convertor was not working properly. is there a simple fix to stop this light from coming up again? as It obviously is a new cat installed. ohh it is a BF mkII typhoon. I cleared the fault code with my flash 2 tuner but I don't want to have to constantly keep doing this.
  • Forged Member
  • Member For: 19y 8m 4d
Posted
I believe this can be tuned out, just wait until you get your custom tune done with all the new bits you have mate
  • Cruise Control
  • Member For: 20y 10m 6d
Posted
yep the BF has 2 o2 sensors,1 behind and 1 infront of the cat so if you put a different cat in thelight comes on but the good news is your tuner can turn it off
Posted
awesome dropping the car off first thing tommorrow for it's tune.... can't wait
  • 3 weeks later...
  • Cryptic Clothing Company
  • Member For: 18y 3m 1d
Posted
I had the same problem when I did the cat. luckly when the car got tuned they turned it off. :msm:
Posted
My car is tuned now and no more light problems
  • Member For: 18y 10m 15d
Posted
Hi, just wanted to know if you are using the sct flash box. I was told you can't turn of the rear cat sensor to stop the light with this box. I this correct?.
  • Drift Queen
  • Member For: 18y 9m 24d
  • Gender: Female
Posted
you cant use the sct flash box, it wont work. I have exactly the same problem. I have had to get a sniper flash box to get it off. Tuner can do it but is waiting on software from USA. Hopefully have my engine light off next week.
  • Member For: 20y 4m 14d
Posted
Your tuner can turn the cat light off with the SCT/Capa advantage software
  • You are a dead set goose
  • Member For: 20y 10m 11d
Posted
Is that what mine is doing mick?
