our06t Mmmmm......BOOST Member 3,135 Member For: 19y 5m 2d Gender: Male Location: central coast Posted 06/08/08 10:30 AM Posted 06/08/08 10:30 AM I got a fairly big gfb one that I'm happy with and it sits nicely under thecross over you can't even see it
Russ F6 Member 641 Member For: 21y 3m 17d Gender: Male Location: Newcastle NSW Posted 06/08/08 10:33 AM Posted 06/08/08 10:33 AM How did you install it to the standard pipework?
our06t Mmmmm......BOOST Member 3,135 Member For: 19y 5m 2d Gender: Male Location: central coast Posted 06/08/08 10:37 AM Posted 06/08/08 10:37 AM just blocked the intake side and it came with a 25mm adapter to suit our size pipe work I can find the box and try get a pic for you if you want
Russ F6 Member 641 Member For: 21y 3m 17d Gender: Male Location: Newcastle NSW Posted 06/08/08 10:39 AM Posted 06/08/08 10:39 AM Should be ok I just need to know the size that it needs to go it so I can order one from turbosmart. Do you think its 25mm?
our06t Mmmmm......BOOST Member 3,135 Member For: 19y 5m 2d Gender: Male Location: central coast Posted 06/08/08 10:47 AM Posted 06/08/08 10:47 AM (edited) it is 25mm inside dia for the rubber hoses old school 1inchgfb also make the stealth desing for xr6 turbomines just called the basic Edited 06/08/08 10:50 AM by our06t
Russ F6 Member 641 Member For: 21y 3m 17d Gender: Male Location: Newcastle NSW Posted 06/08/08 10:49 AM Posted 06/08/08 10:49 AM it is 25mm inside dia for the rubber hoses old school 1inchWill that be it on the link. 25mm onehttp://www.turbosmartonline.com/index.php?id=50
ETM Member 1,194 Member For: 19y 6m 16d Gender: Male Location: syd south Posted 06/08/08 10:52 AM Posted 06/08/08 10:52 AM (edited) Yes it is 25mm there are 3 available, plumb back, supersonic and dual port.Dual port is the best as it will not require you to block off your original plumb back hose but still give you sound.I have a special on all turbosmart gear atm, check the thread in my advertiser section for detailshttp://www.fordxr6turbo.com/forum/index.php?showtopic=44659 Edited 06/08/08 10:53 AM by ETM
our06t Mmmmm......BOOST Member 3,135 Member For: 19y 5m 2d Gender: Male Location: central coast Posted 06/08/08 10:56 AM Posted 06/08/08 10:56 AM you shoulnt need to go the trouble of weld on adapters till you change your pipe work
our06t Mmmmm......BOOST Member 3,135 Member For: 19y 5m 2d Gender: Male Location: central coast Posted 06/08/08 11:01 AM Posted 06/08/08 11:01 AM How did you install it to the standard pipework?
Russ F6 Member 641 Member For: 21y 3m 17d Gender: Male Location: Newcastle NSW Posted 06/08/08 11:03 AM Posted 06/08/08 11:03 AM Yes it is 25mm there are 3 available, plumb back, supersonic and dual port.Dual port is the best as it will not require you to block off your original plumb back hose but still give you sound.I have a special on all turbosmart gear atm, check the thread in my advertiser section for detailshttp://www.fordxr6turbo.com/forum/index.php?showtopic=44659I have the megasonic dual port bov but all I want is the bit of metal that goes into the bov and then straight into my hose.
