July 9, 200818 yr #1 hi guys, I have an idle problem when I pull up and sit in neutral I can hear a "pop" out the exhaust and my car starts to wobble, but all this stops when my air con starts. iv had it at ford so many times but no codes show up so they seem to think its normal. any dipsh*I can tell there is something wrong so can you please help?
July 9, 200818 yr #2 valve springs, cat or somethin 2 do with your tps. clean your throttle body 4 starters.
July 9, 200818 yr #3 Author yeah iv cleaned the tb, injectors and fuel system, brand new exhaust and it was doin it before I got it so its not the cat
July 10, 200818 yr #8 mate myne was just doing that, I thought I bought a dud F6 and was stressing it was fuct!Turns out the intake mainifold gasket had failed only slightly, enough for computer to feel the differences in pressure and freak out, it was as if it was running on 5 cylinders before I had it tilt trayed to ford, they fixed it n its back to normal now, and air con had a big effect on it oo by the wayhope this helps
July 17, 200818 yr #9 MY ute and my old au both have a reasonably rough idle I figured nothing to be worried about
