12FEAR Member 128 Member For: 19y 1m 3d Gender: Male Location: rockhampton Posted 12/06/08 12:38 PM Posted 12/06/08 12:38 PM Hi all I am going to try something some would probably call mental. I am going to turbo my YZ450F dirt bike. Just wondering if anyone else has any knowledge or ideas on this subject?? Any helpful info appreciated. Thanks.
smicky Go Pies!!! Legacy Donating Member 2,852 Member For: 18y 7m 5d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 12/06/08 12:54 PM Posted 12/06/08 12:54 PM What the?Used to work with a guy that had noz on a 1200...scared the sh*t out of me just looking at it!
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 19y 1m 2d Gender: Male Location: Perff, WA Posted 12/06/08 01:18 PM Posted 12/06/08 01:18 PM (edited) not sure if this would help or not, but I remember seeing a few completely insane 'busa's that had hairdryers on them. http://www.dragbike.com/news/02-00/product_mrturbobusa.htmEDIT: anyone got a towel?? Edited 12/06/08 01:19 PM by Superdan
groper Member 611 Member For: 19y 7m 21d Posted 12/06/08 01:20 PM Posted 12/06/08 01:20 PM (edited) ok where to start... my last bike was a YZ450...for starters, id try and talk you out of it, but if you really want to do it then be prepared to spend alot of money doing it.First thing is you will need engine management, as the factory ECU and most aftermarket ones for motos will not be capable of dealin with boost.They run a very high compression ratio standard, so you may need to lower this to run any reasonable amount of boost without pinging even with very hi octane fuels. Also you will almost certainly need an intercooler or you wont be able to get any timing into it at all if you feed it direct hot air with this high comp ratio. Therefore, you wont make stuff all extra power without it. Question is where do you put it and all the plumbing that goes with it?They run a carburettor, so somhow you will need to rerig this as a blowthru setup and change your jetting radically to deal with it.Fitting all the pipe work and turbo itself is gonna be almost impossible as you have very little room, the package is very tight as standard. If you did hang all this gear off the side of it, its gonna get easily damaged when you crash and render its off road abilities rather limited. you also have flying rocks from your front wheel to flick up and damage things not to mention roost from people in front.Then to tune it, you gonna have to start from scratch as I doubt anyone has done this before that you could get to help you.very impracticle dude... Edited 12/06/08 01:24 PM by groper
12FEAR Member 128 Member For: 19y 1m 3d Gender: Male Location: rockhampton Posted 12/06/08 01:37 PM Author Posted 12/06/08 01:37 PM Dam you!!!!!!!!! You just shot me down!! I was thinkin of maybe settin it up as a Drag bike. Extended swing arm and a slick............ intercooler was on the cards. But all sounds too much now. Dam those youtube vids of turbo raptors!!!!!!!!!!!!!!!
dule Legacy Donating Member 1,180 Member For: 19y 5m 6d Gender: Male Location: Sydney Posted 12/06/08 01:46 PM Posted 12/06/08 01:46 PM Youtube is bad influence. I love the video of the R1 turbo doing wheelies in 4th gear.
dule Legacy Donating Member 1,180 Member For: 19y 5m 6d Gender: Male Location: Sydney Posted 12/06/08 01:51 PM Posted 12/06/08 01:51 PM Actualy I think it's doing it in 5th and 6th too
Superdan Well-Hard Bangin' Member Member 3,422 Member For: 19y 1m 2d Gender: Male Location: Perff, WA Posted 12/06/08 02:09 PM Posted 12/06/08 02:09 PM mental
Gavin.K Member 288 Member For: 21y 3m 9d Gender: Male Location: sydney Posted 12/06/08 10:35 PM Posted 12/06/08 10:35 PM (edited) There are guys who turbo and nos up there busa you have to love that. Edited 12/06/08 10:35 PM by Gavin.K
groper Member 611 Member For: 19y 7m 21d Posted 12/06/08 11:37 PM Posted 12/06/08 11:37 PM if its a drag bike only then anythings possible, and practicality is no longer a concern. But being the first one to do it means you make all the mistakes and spend all the money figuring out the best way of doing things... its gonna be expensive and take a long time. at the end of the day, its only 450cc`s. you might make 100hp at the back wheel when its all said and done, is this really gonna satisfy your hunger?much easier to build a hill climb bike and drag that... use a 1000cc 4cyl engine, turbo that (its already been done many times so you will know exactly how to do it and get help with it) and package it all in a custom extended frame. Then youll have an absolute missile running 8sec 1/4 miles...
