  • Member For: 18y 7m 7d
Posted (edited)
Hi my T has now started missing thrrough the entire rev range very faintly but very noticeable when you hold the throttle perfectly still in the one spot. Ive had nizpro springs fitted, 6 new coils and numerous sets of spark plugs and nothing has made a difference. What Now??????????? Oh and by the way my mechanic has a carman scan tool and it did not pick up any faults at all, but he thinks there may be a better diagnostic tool than his as he is a Expensive Daewoo man.
Edited by jared87
  • Legacy Donating Member
  • Member For: 21y 1m 2d
Posted
Were any mods done before it started missing? or did you replace the valve springs as a possible solution to the miss?
  • Yaris member
  • Member For: 20y 3m 14d
Posted
I have no idea where you location is, but check out the site sponsors.
There might be one near you that can have a look :spit:
Posted
Yeah I did but it was only a little pop on idle but now its everywhere, its been about a month since the springs were fitted though.
  • Member For: 19y 25d
Posted
I'm no expert, but do you think it could be fuel related.
Try changing the fuel filter
Posted
ive changed three fuel filters in the last three months, unless it has clogged an injector but that's what I thought the filter was for.
Posted
I don't know then mate, was just trying to help.
Maybe take it to a site sponsor to get checked out
  • Moar Powar Babeh
  • Member For: 21y 12d
Posted
Can your mechanic check your fuel pressure? What about the signal for the crank sensor? Can you get scantool on it and run it up on a dyno to check these issues out?
