  • TRAITOR
  • Legacy Donating Member
  • Member For: 23y 11m 15d
Posted (edited)
Don't think this has been posted yet?
http://www.drive.com.au/Editorial/ArticleD...ArticleID=51241
Get's a good wrap as a whole. XR8 dissapointing.
XR6T and G6ET:
0-100 - 5.1s
1/4 - 13.4 @ 172kph/106mph
Have a read.
Edited by ExAreSix
  • Replies 31
  • Seriously Flukey Member
  • Member For: 22y 6m 13d
Posted
The G6ET looks good value with those performance numbers.
Lowered with some nice 19's and a sunroof it would be a belter.
  • Member For: 19y 5m 18d
Posted
For the record, the air-conditioning was on. There were no stunts, no tricks, we just squeezed the accelerator. It did it like it was brushing its teeth.
that's for the XR6T, you'd think they would turn the air con off for these tests. So without air con it should do 13.3
  • Sucker
  • Moderating Team
  • Member For: 22y 5m 9d
Posted
I assume the air-con would disengage at full throttle anyway, so it shouldn't make too much difference. :shocked:
  • Formerly Turbo6
  • Member For: 23y 8m 26d
Posted
farkin quick for a standard car.
Can't wait to read the replies on LS1.com
  • Member For: 23y 6m 3d
Posted (edited)
My only issue is that Drive gave the G6E Turbo the same times BASED on what the XR6T pulled.
Now, normally this would be fine... only thing is that the G6E Turbo does not have an LSD??
I would have liked to have seen them test the G6E Turbo on it's own instead of just using the same figures for the XR6T...
Edited by Ford_Power
  • Member For: 18y 10m 8d
Posted
would have also been good to get some insight into the manual version with launch control. Hopefully one of the other car magazines/sites will do this.
  • Member For: 19y 8m 19d
Posted
Very quick I'm impressed with the performance of the XR6T bigger brakes would of been good.
Posted
Very good point.
I would expect the G6ET to be heavier than the T as well, so likely a little slower.
  • Member For: 19y 4m 13d
Posted
wouldnt surprise me if ford got rid of the V8 like they did in the late 80s.
