  • Into the laaaake
  • Member For: 19y 3m 20d
Posted (edited)
Get your cat put in the same place as the original, and have them make up a collector to go from your 3 inch cat to your 2 x 2.25 pipes. I would get flanges welded on so you can change things if you want later.
But is there a benefit to doing it like that? As they were planning on using a single 3in pipe from the exit of the cat all the way to a bit b4 the existing exhaust then fit a collector and go into 2 x 2.25 pips and fit a flange there.
where are you located?
Far North QLD.
Edited by hanra
  • Replies 24
  • Member For: 19y 4m 4d
Posted
Far North QLD.
got all the bits you need off a bf typhoon, but your too far away.
cheers
anthony
  • Dropping a turd
  • Legacy Donating Member
  • Member For: 18y 11m 7d
Posted
Far North QLD.
Twin 2.25 flows more than single 3. How much power do you have or intend on making.
  • Into the laaaake
Posted (edited)
What sort of $$$ are you chasing for it all? Is it the front section of pipe incl the cat?
Ah ok, Good point. Ill tell the shop that's how I want to go. Stock at the momment, but would like to see about 280-300rwkw.
Edited by hanra
  • Member For: 19y 1m 5d
Posted
I agree with arronm, get them to make a y piece. and just take out the middle muffler aswell if u havent done that...
  • Into the laaaake
Posted
Was going to leave the middle muffler as I dont want it to drone as it apparently does in the utes?
  • Member For: 18y 7m 6d
Posted
I bought a stainless Magnaflow cat a little while ago and its now time to have it fitted. Its SINGLE 3inch in and 3inch out. Spoke to all the mufflers shops in town about it and it seems that none of them have had experience with fitting a hi flow cat to a STOCK XR6 Turbo exhaust system.
The one shop that ill probably go with suggested doing this:
Flange either end, Run a single 3in pipe out of the cat, kick it sideways towards the passenger side, then send it towards the rear (as per stock) then fit a Y piece with twin pipes leading to a flange so it bolts up to the remainder of STOCK exhaust.
I realise there is this X-force pipe on the market, buts its pretty steep for a piece of pipe....
Heres my wonderful PAINT sketch idea..... How have others done this? Opinions?
Where did u find that force cat and pipe??? It looks the part but u say it was dear how much was it??
Posted
Thanks very much im chasing up that rpm supermart about it.
  • Member For: 22y 4m 8d
Posted
they can order in a y peice , that fits straight up, I think it is about $35.00 for the y peice , then they can weld it up, the exhaust shop does it for me all the time, $450.00 including the cat.
and a bf you just don't need the y peice, so you save about $50.00.
david
