private9 Member 49 Member For: 18y 9m Gender: Male Posted 22/03/08 12:06 PM Posted 22/03/08 12:06 PM Hi All,Just wondering at what sort of rwkw figure does a good 3" exhaust become a limitation?I'd like to stick to 3" for budget and ground clearance, but am just wondering where it will become a restriction?Thanks,Justin.
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 21d Gender: Male Location: SW Sydney Posted 22/03/08 12:09 PM Posted 22/03/08 12:09 PM beleive it or not, but the 3" exhaust is about the same as the standard system in the XR. The standard is Dual 2.25" and that equals 4.5" so do the math. 3.5" is the smallest anyone should go on these cars if they are looking for more than 280rwkw IMO
private9 Member 49 Member For: 18y 9m Gender: Male Posted 22/03/08 12:21 PM Author Posted 22/03/08 12:21 PM well, you're right mate! I just did the maths and got the following results:Surface area in square inches for each exhaust size:Twin 2.25 = 10.5Single 3" = 7.1 Single 3.5" = 15.7Single 4" = 24.6Aside from getting higher quality mufflers, why would anyone upgrade to a 3" considering that the pipework itself is less restrictive in standard form? Note, I am only talking about the pipework, not mufflers.Thanks,Justin.
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 21d Gender: Male Location: SW Sydney Posted 22/03/08 12:31 PM Posted 22/03/08 12:31 PM the pipe work is much of a muchness really, if it has press bends in it, then its crap, but if its mandrel bent then it is as free flowing as possible.Good mufflers are essential - the standard mufflers actually reduce to around 1.75" inside, so they suck basically!Welds are important, but they would have to be pretty sh*t to make a difference.What power are you aiming for? That is the question you need to answer before you start modding
private9 Member 49 Member For: 18y 9m Gender: Male Posted 22/03/08 12:34 PM Author Posted 22/03/08 12:34 PM Yep, naturally mandrel is the way to go!Power goal isn't really known, I'd just like to go up in stages as I'm on a budget, and see what feels good!
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 21d Gender: Male Location: SW Sydney Posted 22/03/08 12:42 PM Posted 22/03/08 12:42 PM well, I would follow the standard system power limits, 280 would be the maximum efficient level, after that you are gonna need to upgrade
private9 Member 49 Member For: 18y 9m Gender: Male Posted 22/03/08 12:43 PM Author Posted 22/03/08 12:43 PM No worries, thanks! The enquiry was actually for another car, which is why I was more interested in the power limits of a 3"
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 21d Gender: Male Location: SW Sydney Posted 22/03/08 12:47 PM Posted 22/03/08 12:47 PM if you can specify what engine/turbo combo it is, I can give you a bit more info, it is very dependant on the application.
private9 Member 49 Member For: 18y 9m Gender: Male Posted 22/03/08 12:50 PM Author Posted 22/03/08 12:50 PM No worries and thanks for the advice so far!It's an AU Falcon engine with a Snort stage 3 turbo kit on it. Currently running 210rwkw on 7psi and an overly rich tune. This is through a factory press bent exhaust, and as I want to do an exhaust next, I was just curious where a 3" will become a limitation.
senna_T Forged Member Legacy Donating Member 15,818 Member For: 19y 7m 21d Gender: Male Location: SW Sydney Posted 22/03/08 12:51 PM Posted 22/03/08 12:51 PM what turbo is it running?
