  • Member For: 19y 1m 5d
Posted
my 05 xr6t used to start like any normal car, turn the key and it would just start and purr straight away.
But since I had it serviced it now starts and revs to about 2000rpm for 3 sec's then drops to about 1200rpm.
It seems to be using heaps of fuel now and I'm just curious as to how others xr6t's start.
To say I'm not happy with the way Range ford have treated me in the past is a understatement, they dismiss any problems I have as "that's normal" and now my RTV is playing up (I think the tps has crapped out) so now I have 2 BA's that run like sh*t.
Any way if you could let me know how your cars start it gives me some more confidence that it's not right.
  • Legacy Donating Member
  • Member For: 21y 2m 24d
Posted
Definitely not normal.
Mine starts first hit of the key and settles to a nice idle.
If you are able try another service center, you may have better luck.
  • Member For: 18y 8m 11d
Posted
mine starts almost first turn, and settles down straight away, and I had it serviced on tuesday with no change afterwards.. doesn't sound good.
  • Member For: 18y 7m 22d
Posted
Mine starts (first time) and sits around 1200rpm after about 5 minutes settles to 400-600rpm!
  • Member For: 21y 8m
Posted
I have had exactly the same problem with my 04 T.
I went to the dealer and they replaced the throttle possition sensor, all fixed. They were able to test it some how and found it faulty.
Six months same thing again. This time the tested and found the same problem, very very rare they told me and too have 2 of them fault on the same car. They replaced it again and all fixed again and that was over a year ago.
So I would imagine you would be under warranty so take it back and tell them it rev's its head off starting first time.
  • BOOST
  • Moderating Team
  • Member For: 23y 26d
Posted
:tonguepoke:
I have had the same prob. Started when dead cold and revs spiked to over 2000. Turned the car off and thought WTF.... Restarted it did it again.
Its only ever done this once though so I never got it checked
Cant you reset the TPS by trying the start the car with wide open throttle ie foot to the floor.
Posted
wait is there something wrong with my car on cold start running @ 1200rpm?
Thought because its cold the air/fuel intake would be higher so it doesn't stall?
  • BOOST
  • Moderating Team
Posted
Nothing wrong with it.. I think they have programed it that way to heat up the Cat converter to make it do its thing
