MiKa Donating Members 4,243 Member For: 18y 10m 24d Gender: Male Location: Melbourne, VIC Posted 09/02/08 02:58 AM Share Posted 09/02/08 02:58 AM All I need to know is, do I use the factory mounting brackets at all....?? I dont have any fitting instructions as I bought second hand... I also only got 2 brackets with the cooler and 2 screws, am I suposed to have more?? As in I can only screw it to the car, in two places... In this pic (not of my car) there are 4 places circled in red to show where the mounting points are, therfore 4 brackets/mounting points and screws needed correct??If so im stuffed...Cheers Mike Link to comment https://www.fordxr6turbo.com/forum/topic/42506-wog-cooler-install-help/ Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 10m 24d Gender: Male Location: Melbourne, VIC Posted 09/02/08 03:02 AM Author Share Posted 09/02/08 03:02 AM Be good if I showed the pic ey.... Link to comment https://www.fordxr6turbo.com/forum/topic/42506-wog-cooler-install-help/#findComment-632029 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 18y 1m 1d Gender: Male Location: Nrth Qld Posted 09/02/08 03:50 AM Share Posted 09/02/08 03:50 AM (edited) No you dont use any of the original I/C mounting hardware. Here are the pics of the brackets I was supplied with my Monza I/C. Edited 09/02/08 03:51 AM by hanra Link to comment https://www.fordxr6turbo.com/forum/topic/42506-wog-cooler-install-help/#findComment-632042 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 18y 1m 1d Gender: Male Location: Nrth Qld Posted 09/02/08 03:55 AM Share Posted 09/02/08 03:55 AM I did post this on here a while ago, but even the search function cant find it???? This might help you out. Righto I got this monst (monza style) intercooler off ebay for bugger all. Fitted it all up this on saturday. I made things difficult for myself due to the fact that I had fitted a PWR Aux trans cooler onto the A/C condensor. This made things very very very squeezy.... Main problem was that I mounted it as low as possible to allow clearance for the stock I/C. I also shifted the horns to underneath the drivers side guard, there was a hole already there for the mounting bolt and a big hole for the wiring!!! Perfect. So I ended up having to drill new holes for the lower radiator support and shift it further back towards the engine. I also had to grind about 2mm out of the backside of the bumper renforcement bar, to allow safe clearance for the intercooler. Because I had to the intercooler further forward then normal I also had to frig around with the mouning brackets. I drilled a new hole in the reo bar on the drivers side, on the passenger side I redrilled a new hole in the bracket. Was a bit of a gin around took me most of saturday to get it sorted. But it turned out ok. Was going to fit the UBP at the same time but im still running a stock tune. So that can wait until I get a custom tune. Horn relocation: Trial fit showed a lot of fouling:Lack of clearance between Trans cooler and I/C:Lack or clearance between I/C and bumper reo bar:Soloution was to drill new mounting holes in the lower radiator support bracket to move it back:That gave me some clearance along with using the angle grinder on the back of the reo bar:Had to modify the I/C mounting brackets a little and drill some new holes: Now I had plenty of clearnace: All done: Link to comment https://www.fordxr6turbo.com/forum/topic/42506-wog-cooler-install-help/#findComment-632045 Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 10m 24d Gender: Male Location: Melbourne, VIC Posted 09/02/08 04:16 AM Author Share Posted 09/02/08 04:16 AM GREAT im missing the two 'L' shaped brackets, but I have the other two..... I may have to FAB something up.... Do you reckon that the 2 brackets that I have is enough to hold the cooler in place?? Link to comment https://www.fordxr6turbo.com/forum/topic/42506-wog-cooler-install-help/#findComment-632048 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 18y 1m 1d Gender: Male Location: Nrth Qld Posted 09/02/08 04:21 AM Share Posted 09/02/08 04:21 AM No. They are only the lower brackets for the left and right hand side. Those two L brackets couldnt be any easier to make up!!!!! Link to comment https://www.fordxr6turbo.com/forum/topic/42506-wog-cooler-install-help/#findComment-632050 Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 10m 24d Gender: Male Location: Melbourne, VIC Posted 09/02/08 04:50 AM Author Share Posted 09/02/08 04:50 AM hmmm I dont have anything with me at home and im home alone so cant drive anywhere... Link to comment https://www.fordxr6turbo.com/forum/topic/42506-wog-cooler-install-help/#findComment-632056 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 18y 1m 1d Gender: Male Location: Nrth Qld Posted 09/02/08 04:54 AM Share Posted 09/02/08 04:54 AM Taxi cab, foot falcon? Have you already started pulling your old cooler out? No point bodgin it when you just have to pull it all apart again to install it properly. If you only fit the lower brackets in will try to pivot forwards or backwards. If your desperate perhaps you can cable tie it in place around the upper region to prevent it from moving? Link to comment https://www.fordxr6turbo.com/forum/topic/42506-wog-cooler-install-help/#findComment-632057 Share on other sites More sharing options...
Mr Man Mad Scientist Member 816 Member For: 20y 7m 16d Gender: Male Location: Vic Posted 09/02/08 06:25 AM Share Posted 09/02/08 06:25 AM Be good if I showed the pic ey....hey that's my ute as hanra has said u get the 4 brackets supplied, and u use the nuts off the original cooler mounts.mine came with 4 new bolts and 4 new brackets, I did have to bend them slightly which wasnt to hard.never had any issues with transcooler as mine is manual, nor did I have troubles with the bumper reo bar.hope that helps.best of luck with it MiKa Link to comment https://www.fordxr6turbo.com/forum/topic/42506-wog-cooler-install-help/#findComment-632099 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 18y 1m 1d Gender: Male Location: Nrth Qld Posted 09/02/08 09:04 AM Share Posted 09/02/08 09:04 AM The transcooler on mine gave issues because I mounted it to low, I had to clear it and the reo bar. If you dont have the trans cooler there, or mount it higher, then it will fit no worries! Link to comment https://www.fordxr6turbo.com/forum/topic/42506-wog-cooler-install-help/#findComment-632137 Share on other sites More sharing options...
