January 28, 200818 yr #1 As the title says I'm interested to know what RWKW and torque figures are being obtained with the standard ford x-over ????How restrictive is it??Should it run 320 RWKW?? Would extra turbo psi be necessary with the standard ford item??
January 28, 200818 yr #2 300+ kw is do'able with the stock Xover, but as you have already stated removing the restrictive Xover will allow you to make the same power with less boost.
January 28, 200818 yr #3 Author Say I want 320 RWKW......How many extra psi would be needed with the stock crossover ??? Extra 2 psi maybe???I'm guessing.....someone else no doubt will have a better idea....
January 28, 200818 yr #4 ok, well I had the stock crossover and made 313 - after a re-tune with RAP1D's piping and around battery intake, I now make 340rwkw on the same boost...If there is any question as to whether you should replace it - the answer is YES!It takes alot of strain off all of the engine components, also improves throttle response on and off boost
January 28, 200818 yr #5 Author Thanks Pat,Yeah looks like I might have to do it........it's a big step for me though 'cus it's the first mod which will be visible.....doh;;;;It would be nice if someone made a unit that looked just like the OEM but was less restrictive....
January 28, 200818 yr #6 there is always kevs from process west, but you can get Chris to make them up black and supply black silicon hoses for a more factory look. Kevs would also mate to your cooler easier I guess
January 28, 200818 yr #7 have made 370rwkw with stock crossover just needs more boost less timing, not the ideal solution
