  • Uncle Bulgaria was gender challenged
  • Member For: 21y 1m 5d
This isnt a debate about to badge or not to badge, just trying to replace my previously mauled badges...
If anyone could help me I'd greatly appreciate the LOCATION of the badge on the boot if someone could measure distances from edges etc...someone that has the badges on from factory. I only have access to a non-turbo XR and I reckon the badge isnt in the factory spot anyway...
Tis the location of the XR6 badge Im after (given the turbo badge effectively places itself if you get the XR right)
Call me anal!!
At 20 a pop I'd like it right ;)
Thanks for any help
Edited by PepeLePew
https://www.fordxr6turbo.com/forum/topic/40376-stock-xr6-turbo-badge-location/
  • Forged Member
  • Member For: 18y 3m 17d
just draw a straight line across from the Falcon badge, the Xr6 Badge lines up with that
  • Sucker
  • Moderating Team
  • Member For: 21y 29d
Isn't the "XR6" on a turbo slightly higher than on a NA though? As in the line you speak of going between the "XR6" and the "TURBO" ? :roflmbo:
that's why Im confused, and the number of cars that have been butt whacked and had there badges replaced in various positions and angles :)
Hey thanks, quick guess says the centre line of the Falcon badge is the centre line of the two badges also...?
  • Forged Member
ok, I just took some measurements, bare with me:
The left-most top tip of the "x" is 21cm from the top of the boot lid, the right most top tip of the "6" is 20.5cm from the top of the boot. The bottom of the turbo badge is 10.5cm from the bottom of the boot. On the left side of the XR6 badge, it is 2.3cm from where the number plate recess starts, and on the other side it is 2.7cm from the edge of the boot.
I know this is tricky to understand, but I can't put a photo on at work..hope it helps!
Legendary Senna! Thank you, hopefully this also helps walking anus's like me with the search button in the future :)
  • I miss her...
  • Member For: 20y 8m 4d
Id say that's correct. I went trawling around a dealer looking at new ones to get mine perfect. Then I f*cked it and put it on a slight angle. Came straight back off and I have not tried again since. 25 bucks well spent :roflmbo:
Edit: Cheers for the measurement senna... I might give it another go.
Edited by TURBOXR
